Old 03-02-2011, 05:04 AM   #19
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i dont see how this could be anything else besides a bluetooth or a mounting point.....
Old 03-02-2011, 11:56 AM   #20
YAR1S
YAR1S's Avatar
that might be something he has wedged in between the mirror and headliner to stop some of the mirror vibration....
-Jen <3
Old 03-02-2011, 12:24 PM   #21
^ hands free microphone (that's my car).
Old 03-03-2011, 04:17 AM   #22
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Let's see it installed!
Midnight Drifter is offline   Reply With Quote
Old 03-03-2011, 01:22 PM   #23
AppleJacks716
Drives: 2010 5 Door
Here is how I mounted mine.
I used a dremel to cut the visor off the plastic mount. Then kept shaving away the plastic mount until the "L" bracket fit in it. It turned out nice. Very oem looking compared to seeing the sheetmetal.
AppleJacks716 is offline   Reply With Quote
Old 03-03-2011, 04:28 PM   #24
^ That's a lot cleaner than my install.
Old 03-03-2011, 04:54 PM   #25
Yaristeve
Drives: 3-door hatch
I've been studying the headliner mounting in the service manual. Is it really so strong and rigid that things such as the grab handle (and your wink mirror) can be mounted to it without being anchored into the roof structure? I was thinking of mounting my GPS to the headliner and taking power from the driver side "personal light".
Old 03-03-2011, 06:22 PM   #26
matthewai
matthewai's Avatar
Drives: it is kinda stock
Thumbs down
dudes just all up in the "i dont see how" mode makin me look like a fool
Old 03-03-2011, 07:02 PM   #27
PK, it's a series of fixed, flat mirrors that give a wide field of view. I can even see out my front windows with it. Really helps eliminate the blind spot when you get used to it.
Yaristeve, no, all of those accessories clip/mount into metal underneath the headliner.
Old 03-03-2011, 07:17 PM   #28
AppleJacks716
Drives: 2010 5 Door
On my civic I first used the glue on windshield mounts. They work alright. It uses a silicone based glue. It's a nightmare attaching them and making sure everything lines up. If you hit a bump hard enough, like most railroads, it flops down and you are looking at your lap. If you hit a really big bump it falls off. Use the visor way to install. Much more rigid and you don't get nearly as much vibration in it.
Old 03-26-2011, 02:46 PM   #29
Tylermayer
Tylermayer's Avatar
Drives: 2007 Toyota Yaris
please show/tell me how to install by taking off the sun visor
Tylermayer is offline   Reply With Quote
Old 03-26-2011, 02:59 PM   #30
^ see post #23
Old 03-27-2011, 02:09 PM   #31
Trubin
Trubin's Avatar
Drives: 2009 Toyota Yaris Hatchback
If someone behind you has high beams on, wouldn't it totally blind you?
"Dat's only in da moning."
Trubin is offline   Reply With Quote
Old 03-27-2011, 02:18 PM   #32
Tylermayer
Tylermayer's Avatar
^ see post #23
i know but i cant figure out to get it off
Old 03-27-2011, 03:23 PM   #33
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I remember when those first came out and we put them in our cars,cool then,cool now.
Old 03-28-2011, 12:13 PM   #34
Yaristeve
All of the panels are tinted so it's not too bad. If you've ever driven a car with an automatic dimming rear view mirror, it is almost as dark as that but all of the time.
Old 03-28-2011, 01:31 PM   #35
AppleJacks716
Drives: 2010 5 Door
1 Completly remove your visors.
2.Use a dremel to cut off the visor mounts
3.Use a dremel to cut a slot for the wink brackets
4. Install the bracket onto your car (pain in the butt, because you have to press them in fully put together)
5. Install wink mirror onto brackets
Yes you ruin your stock visors, yes the brackets will probably never come out again with out totaly ruining them. But you will need to buy new visors to replace them anyways. I didn't use an screws or glue for attaching the brackets. The fit is so tight you don't need them. My mirror doesn't move at all. I have no pictures of the install.
Old 03-28-2011, 02:26 PM   #36
racerb
If you want to get out on the cheap, the CIPA model 34000 is what I use in my track car, it's 12" wide with a panoramic view. Here is the link from Summit Racing, http://www.summitracing.com/search/P...d=cipa+mirrors Clips onto stock mirror and gives almost a 180 view of whats behind you!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
CIPA 36500 - auto dimming mirror w/ map lights, compass, outside temp. -- installed. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 11 04-05-2015 03:36 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Help! Replacing driver's side mirror temps2020 DIY / Maintenance / Service 3 11-11-2010 11:08 AM
Replacing Passenger Side Mirror thorcor06 DIY / Maintenance / Service 4 09-03-2010 12:10 AM
Gentex K31 - auto dimming mirror w/ map lights, compass, outside temp. -- installed. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 22 01-06-2009 07:34 AM
