Old 03-27-2011, 03:10 AM   #1
Mister Z
Drives: 08 Yaris HB
stretch tires on my aftermarket wheels
Hey guys,
I just put on my new wheels with stretch tires. The problem is that there is a slow leak on one of the wheels. I don't think the stretch would cause this problem. The tires on there are the stock tires(185/50) on a 8 inch wide wheel. I mean the other wheels/tires are showing no loss of air. The wheels are brand new. And the tires had no leaks prior to putting on the tires to the new wheels. Any ideas? If the tires are the problem, anyone have an idea on what tire would be best for a stretch?
Thanks in advance!
Mister Z is offline   Reply With Quote
Old 03-27-2011, 04:54 AM   #2
Make sure the place that mounted the tires mounted it right. Otherwise, there's probably some damage somewhere on the tire.
Falken tires, especially the 512's are known for awesome stretching.
Old 03-27-2011, 04:55 AM   #3
Otherwise, browse through here: http://www.wrongfitmentcrew.com/foru...-Tires-Gallery
Old 03-27-2011, 07:23 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
check valve stem seals also.. what type are you using? are you using the TPWS?
Old 03-27-2011, 01:41 PM   #5
Mister Z
Drives: 08 Yaris HB
Koo thanks guys. And as far as the valve stems im using what the tire shop gave. They look the same as stock.
Old 03-27-2011, 04:25 PM   #6
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
most likely a leak on the bead,pretty common on stretched tires.depending on how far you stretched the harder it is to keep the smal leaks away,have them recheck the seal on the edge in the water bath.
Old 03-27-2011, 04:53 PM   #7
ilikerice
ilikerice's Avatar
to the water tube check like bzinn suggested.. if anything, take the wheel off and do it yourself first. then dry it off and mark where you found it.. then take it to the shop and tell them.. hey.. FIX THIS! lol.. but in a nicer way
Old 03-27-2011, 06:28 PM   #8
Mister Z
Drives: 08 Yaris HB
Koo. Thanks for all the help guys!!! Hope this fixes my problem!!
Old 03-28-2011, 10:26 AM   #9
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
sometimes if you don't clean the bead of the tire off before mounting them, a little piece of dirt or rust get imbedded in the rubber from the previous rim. I always wire brush the bead off if I'm switching tire from one set of rims to the other.
Old 03-28-2011, 12:01 PM   #10
33OH
Drives: '08 Yaris
Yep. Dismount tire and clean where the bead seals.
Old 03-28-2011, 04:33 PM   #11
RedRide
RedRide's Avatar
I agree.
This is often overlooked and can be a problem with any tire.
Also, many tire dealers/installers will apply a bit of soapy water to the tire/rim bead area to insure proper seating and sealing.
18 TRD wheels and Tires Nor-Cal contraband831 Items for Sale by private party 12 02-20-2011 10:27 PM
Rays/Volk TE37 race wheels - 15"x7", 4x100 pattern, w/ NEW Falken Azenis rt615K's ozmdd Items for Sale by private party 5 04-29-2010 01:37 AM
Stock 2009 Wheels and Tires -NY/CT/NJ XYaris Items for Sale by private party 0 01-04-2009 05:43 PM
