Old 03-27-2011, 08:26 PM   #1
david_mackk
Drives: Yaris 5dr LB
2nz-fe turbo help
I have searched for days for turbo kits for the 2nz-fe and have only found the GReddy bolt on kit. I found this article where a guy bought a hks bolt on kit which came with a gt25. Anyone know where I can find this kit or any suggestions for a different GOOD bolt on kit?
Here is the article
http://autospeed.com/cms/title_Baby-...6/article.html
david_mackk is offline   Reply With Quote
Old 03-27-2011, 09:45 PM   #2
cdydjded
Drives: Yaris LB Turbo
The Yaris is not available here with the 2nzfe. Both Greddy & HKS do not bring turbo kits here to the US for neither the 1nzfe or 2nzfe. If your serious on a kit you are going to have to go the custom made route. A custom kit from a 1nzfe should fit, the manifold is the only issue. If you could get a pic of a exhaust gasket I could try to verify if they are the same.
Old 03-28-2011, 01:32 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
technically any kit for the 1NZ should bolt onto the 2NZ. They're the same engine with different displacement. You'd just need to have it tuned to with with the smaller motor.
Old 03-29-2011, 07:07 AM   #4
david_mackk
Out of all the Research iv done I'm 90% positive to say that the 1nz and 2nz have the same manifold. What parts will I need to build a custom kit, i will be getting a performance shop to install and tune the car. I'm not rich either so if some good quality but not to expensive parts can be suggested that would be great.
Thanks!
Old 03-31-2011, 09:35 PM   #5
david_mackk
Cmon guys help a fellow YW member out :)
Old 03-31-2011, 10:48 PM   #6
cdydjded
http://www.yarisworld.com/forums/showthread.php?t=29053
Everything in the above post. PM me if you serious on getting a turbo kit.
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
Turbo for 2NZ.... Centurion2200 Forced Induction Forum 9 08-25-2007 06:14 AM
