Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-28-2011, 04:15 AM   #1405
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
Originally Posted by duke_afterdeath View Post
tol advice ng kabayan electrician yung design po ng wirings ng headlight at foglight ng yaris natin ay di angkop sa mas mataas ng wattage (OEM lang daw talaga ang pwede, unless gamitan nga ng relay or ballast for HID naman) marami na din daw sya ginawa na nasunog ang fuse wires at hindi lang ito sa toyota or yaris may mga ginawa na din syang ibang kotse na same problem,,, gaya nga ng nabanggit ni kapatid na rosco sa safe side na tayo... pero cyempre nasayo ang desisyon tol sakin lang po base sa experience ko mas lalaki ang problema at lalaki pa ang gastos
rosco is offline   Reply With Quote
Old 03-28-2011, 04:23 AM   #1406
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by EjDaPogi View Post
well said. mabuhay si duke_smoke
tol nawala na yung after SMOKE na lang ano kaya susunod
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-28-2011, 04:30 AM   #1407
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
tol, kasi may RELAY na! kaya ganon! wa-pak!
EjDaPogi is offline   Reply With Quote
Old 03-28-2011, 04:35 AM   #1408
duke_afterdeath
wala bang bababa sa inyo jan d2 may ipakikidala ung pinsan ko jan papunta d2
Old 03-28-2011, 04:38 AM   #1409
EjDaPogi
EjDaPogi's Avatar
i-RELAY na lang natin!!!
Old 03-28-2011, 04:39 AM   #1410
duke_afterdeath
busettt!!!
Old 03-28-2011, 04:39 AM   #1411
kiel12
kiel12's Avatar
Drives: 2011 toyota yaris Y
duke si jherton tanungin mo kc yung isang kasama nya sa work eh weekly ang punta dyan sa riyadh..
kiel12 is offline   Reply With Quote
Old 03-28-2011, 04:40 AM   #1412
duke_afterdeath
ah ok tol, salamat...
Old 03-28-2011, 04:58 AM   #1413
duke_afterdeath
Originally Posted by rye7jen View Post
Ricky ilang watts yung white bulb mo?
tol rye, 380watts ung nakakabit ngaun kay tol ricky....
Old 03-28-2011, 05:26 AM   #1414
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
tol no need na for the fuse, as you can see ginamit natin sa installation ung unang original socket na naka install naman sa fuse at switches sa fuse box.. at dahil may relay nga di na po need magpalit ng higher fuse.. actually diko naitanong ito sa electrician paki correct na din po mga kayaris then ask ko din yung gumawa if tama nga yung pananaw ko, hehe..
Duke, what i mean is yung relay to battery.. nag-search na kasi ako about sa relay installation at naglalagay sila ng inline fuse between the relay going directly to the battery, yan kasi yung isang rason kaya natagalan ako bago ko na-install yung nabili kong busina. Worried lang ako kung ano magiging dis-advantage nito in the long run.. Pero nung nakita ko yung relay na kinabit kay pareng brosco eh wala rin silang nilagay na inline fuse..
Eto yung gusto ko tukuyin:
Paki-correct na lang po or baka may namiss lang ako.
rye7jen is offline   Reply With Quote
Old 03-28-2011, 05:29 AM   #1415
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Thanks tol, chineck ko kahapon yung watts nung white bulb na binili namin ni tol brosco 550watts .... pansin ko parang nagcocorrode na yung terminal ng headlight mismo..normal ba ito? Kuhanan ko ng pic pag makalibre..
Old 03-28-2011, 05:40 AM   #1416
EjDaPogi
EjDaPogi's Avatar
scary naman itong post mo. how much more to us na gumagamit ng 1,200W? waaa!
Old 03-28-2011, 05:44 AM   #1417
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Ej, no need to worry, wala naman sign na natunaw or nasunog mga wires, taka lang ako bat parang may corrosion na yung terminal connection nung headlight. Iniisip ko na lang na sana e epekto lang ng tubig or something.
Old 03-28-2011, 05:45 AM   #1418
duke_afterdeath
Attachment 40739
copy tol, walang fuse in between the battery and relay sa kinabit kay storm, cguro pwede ding lagyan para mas safe...
Old 03-28-2011, 05:48 AM   #1419
EjDaPogi
EjDaPogi's Avatar
un ba yong parang toothpaste pag hinugot mo ung socket?
Old 03-28-2011, 05:50 AM   #1420
duke_afterdeath
tol normal lang yan wag lang mag aamoy sunog ant medyo nadidiform na ung terminal or socket ng headlight... pero cguro tol wag mo na hintayin un
Old 03-28-2011, 06:00 AM   #1421
syntax
syntax's Avatar
normal yan pre' nagtaka din ako dati kung bakit ganun ang itsura nun na parang luma na malangis, pero nakita ko rin un sa ibang kayaris ay ganun din pala ang itsura...
Old 03-28-2011, 06:05 AM   #1422
duke_afterdeath
tol ganito ung harness na kinabit kay storm iba lang ang socket nito, wala syang fuse, yung nakikita nyong white casing sa wire na pula na ikakabit sa battery ay connector lang yun para madali syang i-disconnect sa battery if ever needed...Name:  H4 relay harness..jpg
