![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
NRG and still have horn button??
i just got an NRG hub adapter, quick release, and wheel installed.. and i could not keep my horn cause of the clock spring being taken out... is there anything they sell that would enable me to hook up my horn normally like aftermarket clock spring or maybe something like a brake gyro on a gt dyno bike??
And i remember reading about a resister to keep the airbag light off... any help, links, info would be great
"It hurts more when its wet" Last edited by Jerkratt; 04-08-2011 at 07:59 AM. |
Here's and interesting idea on how to keep the horn with a hub that doesn't have a clockspring:
http://www.nrginnovations.com/support/entry/14/ For the airbag, you need two 3 ohm resistors. You will connect one between the yellow/red and yellow/green wires and the other between the yellow and yellow/black wires. I have a bunch of the resistors if you can't find them locally. Once you connect the resistors you will need to clear the DTCs logged by the SRS ECU caused by driving with the airbag disconnected: http://www.yarisworld.com/forums/sho...d=1#post557473
You are the best! Was hoping you would chim in :D ima try and get the resisters at radio shack
"It hurts more when its wet" |
does the watts matter on the resistors
http://www.amazon.com/s/ref=nb_sb_no...sistor&x=0&y=0
#5 | |
done and done.. ty again all i gotta do is get a better contact for the horn un bent a key ring for now
(^)-_-')
you can also pick up resistors at any radio shack or if you have a ohm meter just make your own with a solder..
Meow
Drives: 2008 Yaris, White Hatchback Join Date: Sep 2009
NEWPORT CIGARETTES!! CHEERS!!
i got the resistors from amazon FAST as hell and already installed them TY scott and turned my air bag light off as well and hooked up the horn
actually its full of pennies.. haha i hate newports... marlboros FTW!
