Michael
Drives: 07 Silver Yaris Sedan Join Date: May 2007
powdercoat ?
just wondering if it would be possible to powdercoat the heatshield to the afe intake. don't know if powdercoating plastic is possible and if so if it would last in a hot engine bay.
negative.. you have to bake the item your powder coating @ 400-500 degrees for a few hours.. i dont think the plastic will hold up to those temps
try using dye. id test it on another plastic and make sure u are doing it right Last edited by ilikerice; 04-04-2011 at 04:59 AM. Reason: dye |
Michael
is there high temp spray paint for plastics that would work?
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you can use vht's plastic polymer paints, or if you're familiar with spike network and the power block you can head to their site and use that brand (i forget) but if it's plastic you want a flexible paint...and if it doesnt say it right on the front you'll get chips and cracks in a matter of days.
you can also put an elastomer into a regular spray paint for car exterior and make it a plastic paint. and then you can spray it in any paint gun. you dont really need high temp for under hood unless it's ON the engine radiator, or any other hot SURFACE itself. you'll need 1600+ for header, 500+ for engine and components and radiators, and you can get away with 200+ for anything else in the engien bay. also, if you wanna do your brakes, you can get away with the 200+ unless you're racing and then you'll need 500+ temp range. the boiling point of dot4 racing fluid is just over 400* so if you're hotter than that you'll have other problems. |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
Plastic? The heat shield on my aFe is metal.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#6 | |
^ correct. As a matter of fact, the AFE shield comes with crinkle black powdercoating.
Michael
thank you for the help. i don't yet have an afe i'm just planning for the future. from all the pics i've seen the heat shield looked plastic. my bad
now that i think about it mine's metal too.
| powdercoat prices | SLIK4 | Cosmetic Modifications (Exterior/Interior) | 10 | 07-28-2010 01:32 PM |
| Chrome, or Powdercoat your steelies? | blacksan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-04-2007 12:12 AM |
