Old 04-05-2011, 04:19 PM   #1
Per Kristian
Drives: Yaris D4D
Someone know what parts I need to chang to get automatic klima control in my Yaris?
Hi!
Want to change my manual clima control to automatic clima control in my 2007 Yaris. Do anyone know what kind of parts I need for this work. I have a donor car, but do not know what I need.
Thanks for the help
Per Kristian is offline   Reply With Quote
Old 04-05-2011, 04:45 PM   #2
If you do some searching, there is a thread that has the info. It is over $2000 in parts that have to be changed.
Old 04-05-2011, 04:58 PM   #3
Per Kristian
Drives: Yaris D4D
Tried to seach, but maybe used some wrong words. Do you have a link for me.
Old 04-05-2011, 05:00 PM   #4
Freedan
Drives: 2010 Yaris Bayou Blue 3DR Lift
Ouch $2000. Guess I'll be content with turning the knob.
Freedan is offline   Reply With Quote
Old 04-05-2011, 08:31 PM   #5
http://www.yarisworld.com/forums/sho...igital+climate
Old 04-05-2011, 08:36 PM   #6
If you can source the parts used from Europe or Japan it can be done considerably cheaper (~$500). Echo_hrs purchased two sets of parts from the Yahoo Japan auctions, and sold me one of them. I figured out how to make it work on a USDM Yaris, and actually still owe him a plug and play harness to get his working.
Old 04-06-2011, 05:54 AM   #7
Per Kristian
Drives: Yaris D4D
Thanks for your help Scott!
Did you find out if all the parts on this list is nessesary? I live in Europe, and have a donor car to pick the parts from
Did you fit this in your car. Do you have picture of the fitting :-)
55900-0D210-B0 Control Assy, Air Conditioner
(This is the entire center dash assembly including the "knobs", electronics, and trim)
87106-0D020 Servo Sub Assy, Damper (For Airmix)
87106-0D040 Servo Sub Assy, Damper
87106-0D030 Servo Sub Assy, Damper (For Mode)
(These three replace the manual dampers with ones which are controlled by the above part)
82212-52020 Harness Assy, Air Conditioning, LHD
(I believe that this is the entire cable assembly, including connections to the above and below parts)
88625-47031 Thermistor Cooler (Solar Sensor)
(Sensor mounted under upper dash)
88625-22131 Thermistor Assy
(Sensor mounted in front bumper)
88625-47021 Thermistor, Cooler
(Sensor mounted behind AC controls)
88650-0D160
(This is the AC control module, which is mounted to the bottom of the AC assembly)
Old 04-06-2011, 06:46 AM   #8
One more part that is missing from that list is the fan assembly. On the "automatic AC" cars, the fan has different circuitry for the speed control. We didn't realize this until after we had the parts in hand, so I had to build a circuit to convert our fan to work with the automatic controls.
Here's a picture of it up and running on the bench. I haven't installed it in my car yet.
Old 04-07-2011, 08:48 AM   #9
Per Kristian
Drives: Yaris D4D
Your skills and knowledge are amazing :-)
Thanks
PK
Old 04-07-2011, 09:43 AM   #10
Out of curiosity, are there other parts available on the donor car? I would like to get an ECM and an instrument cluster from a European Yaris for experimentation.
I was going to visit a wrecker outside of Paris, during a vacation last summer, but my wife wouldn't let me spend a day looking for car parts rather than seeing the sites.
Old 04-07-2011, 12:51 PM   #11
Per Kristian
Drives: Yaris D4D
You got PM :-)
FS Part 1: Many Stock Yaris Parts Kenshin Items for Sale by private party 5 11-23-2009 10:17 PM
LF: Yaris / Vitz / Echo hatch accessories / parts! Keej_05RS General Yaris / Vitz Discussion 3 12-08-2008 09:43 PM
