Old 06-20-2006, 02:14 PM   #1
IntensePower
Drives: 350z, supra, xb, 240sx
Perrin Crank Pulley
If the Yaris is using the same motor as the xa and xb the perrin crank pulley could work.
Just FYI
Intensepower
480-926-8797
www.intensepower.com
IntensePower is offline   Reply With Quote
Old 06-20-2006, 07:14 PM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Just FYI
I have asked this many times, mainly over @ ScionLife.com, but what else will fit?
Old 06-21-2006, 02:12 AM   #3
heylookitsjames
maintenance of momentum
Drives: 2007 5spd 3dr
I would assume any of the actual engine parts will fit, be it spark plugs or cams (if they even exist for the scions), but ancillaries may be slghtly different due to chassis design and engine bay layout (like intakes).
What I would like to know is if the suspension components are compatable or not...
heylookitsjames is offline   Reply With Quote
Old 06-21-2006, 10:47 AM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
They're not. The suspension is different in the yaris. The pickup points are slightly different.
Colin Chapman disciple
Old 06-21-2006, 05:41 PM   #5
IntensePower
as mentioned in one of the tein threads they are releasing coilovers in september for suspension.
besides some of the cusco parts i do not know.
if the transmission is the same the perrin short shifter might work.(i'm pretty sure it is) the perring SS should work and they are throw adjustable.
We hope to get a Yaris in our shop soon to look into parts fitment with more detail.
Intensepower
480-926-8797
Old 07-07-2006, 12:28 AM   #6
soros151
Another question... :D
soros151's Avatar
Drives: Scion tC 06
I think there even is a strocker kit for xBs, At least I heard about the development on them. Don't know how much will they upper too.
*One tire nearer to my goal*
soros151 is offline   Reply With Quote
Old 02-22-2007, 12:08 PM   #7
ZPIracing
ZPIracing's Avatar
Drives: Scions
The xB pulley will not work. Well it might but would not be ideal. The Yaris uses a single belt design while the xB runs two belts off the crank pulley.
ZPIracing is offline   Reply With Quote
