Old 04-19-2011, 09:51 PM   #19
thepartsmancometh
Drives: '08 LB, '07 WRX
Originally Posted by goliath1812 View Post
+1. Pink spray on the underside of you hood.
not even that bad sometimes. Often, our techs catch just a pink residue on the pump or block itself. it can be hard to spot, but better fixed sooner than later
thepartsmancometh is offline   Reply With Quote
Old 09-13-2012, 08:17 PM   #20
RickSWEF
Drives: 2008 Yaris Hatchback
Water Pump Replaced
I have less than 75K miles and my pump bearings started to make the worst sound ever. I thought my 2008 Yaris was falling apart.
Just bought the replacement pump for about $35 and some anti-freeze for under $6. I think that's a great deal, without the warranty.
If you have the warranty, be sure to use it as often as possible.
RickSWEF is offline   Reply With Quote
Old 09-13-2012, 08:58 PM   #21
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Had my water pump replaced under warranty .. not sure of the mileage when it happened.
edmscan is offline   Reply With Quote
Old 09-14-2012, 12:26 AM   #22
detroiter
detroiter's Avatar
Mine crapped out probably around 115,000
Old 09-14-2012, 05:16 AM   #23
bronsin
bronsin's Avatar
Originally Posted by hyprmiler View Post
not to start an argument over warranties, but I've found that putting a little bit away every month and budget for a repair before it happens saves over buying an extended warranty if you plan on keeping the car for an extended period of time.
Companies make money on the warranties they sell. Its that simple. Statistically the consumer SAVES money by not getting the extended warranty.
I told the Toyota dealer when I bought the car (and they twisted my arm to extend the warranty) "Im paying top dollar to buy a Toyota when I would save money buying a Korean car. If anything serious goes wrong with the car I wont be buying another Toyota!"
Old 09-14-2012, 05:44 AM   #24
nookandcrannycar
225,703 miles -- original water pump still on the car.
Old 09-14-2012, 09:58 AM   #25
NEexpat
Drives: 2009, auto, 4dr LB
I was going to say that the water pump problem appeared to be isolated to 2008 and earlier models,............................until I read Kongo-Otto's post.............................................. ......................................nevermind.
NEexpat is offline   Reply With Quote
Old 09-14-2012, 03:34 PM   #26
Kal-El
Kal-El's Avatar
I got the usual pressure to purchase the extended warranty (to 100K) when I bought mine with 34,000 miles on it. I made the correct prediction that it would be extremely unlikely for anything expensive to go wrong before 100K on a Yaris. I'm now at 126,000 and have not needed a single repair. It's still like new.
I think they wanted something around $1,000. Would have been 1,000 profit for them.
Old 09-14-2012, 04:01 PM   #27
NEexpat
Any Toyota Certified used car, 100k mile powertrain, warranty blah, blah, blah, the water pump is covered under that certified used warranty.
Here
Old 09-14-2012, 08:42 PM   #28
bronsin
bronsin's Avatar
I was thinking about the Yaris/Toyota waterpump issue.
When a waterpump on a 1970s era American car went, the pulley wobbled and the pump leaked. It was possible to add water and drive maybe for a couple of weeks. But if you did that pretty soon the pump just blew and massive ammountes of coolant came gushing out.
When mine went the pulley didnt wobble at all. I checked the coolant level weekly. It was never low. The ammount of coolant leaking as very minimal. There were pink stains on the underside of the hood, but never any dripping from the block onto the ground with the engine running. I t was about three months from the time I first noticed the underside of the hood until the dealer did the pump under warranty.
If I was broke I would have kept driving it and checking the coolant level daily. Also checking under the car with the engine running for drips.
I felt a little silly taking it to the dealer but it was on their dime so why not?
Has anyones pump gone massively? Or are they all just a little leak with no pulley wobble?
Old 09-14-2012, 10:28 PM   #29
NEexpat
^bronsin, so yours went too.
Why did I think it had all been sorted by the time the 2009's came out, must have been something else....................
* I'll have a look at mine in the morning.
Old 09-15-2012, 07:17 AM   #30
YAR1S
YAR1S's Avatar
I changed mine at about 90k miles. Mine's bearings had gone bad... it sounded AWFUL.
It started sounding weird for a bit, no signs of leaking... I knew it was coming from the belt area but didnt get it checked out before going on a 14 hour round trip and by the time I got back my engine started to sound like a dirty diesel. I took it to toyota dealership and they said it was the waterpump had gone bad. They took it out and found out it was just the bearing(s) and told me since the labor was already high to just replace it and the serp. belt. pretty expensive fix but its much better now.
-Jen <3
Old 09-15-2012, 09:53 AM   #31
bronsin
bronsin's Avatar
Hmmmm.
No leak just noise.
Now that the car is out of warranty (or will be in a couple years) Im wondering if I get a little leak to just run it and not fix it since Ill have to pay.
But what happened to yours had to be fixed...
Old 09-15-2012, 01:25 PM   #32
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
2009 Yaris here...
Mine broke with about 20,000 miles on it.(Water pump) Toyota replaced it for free.
Twistoffate0817 is offline   Reply With Quote
Old 09-22-2012, 04:51 PM   #33
Astroman
Modded Moderator
Astroman's Avatar
Please try to post your threads in the correct thread section. It's getting old moving all the stuff from the "general discussion" when this was service related. I've moved it to the proper sections
Old 09-25-2012, 12:31 PM   #34
taka
Drives: 2008 Sedan
@62953 km, Dealer changed my 08 sedan under warranty during a route maintenance visit. Had light sign of anti-freeze around pulley.
taka is offline   Reply With Quote
Old 09-25-2012, 01:16 PM   #35
nookandcrannycar
glad you got your pump replaced at no cost to you though!
^^^^^This. In addition you don't have to worry about the warranty company going out of business/declaring bankruptcy, nor trying to deny your claim.
Old 12-08-2013, 09:01 AM   #36
glvu
Drives: yaris
2007 toyota yaris water pump
I took my 2007 toyota yaris with 120K to the dealer last week and they told me that I my water pump is showing signs of leakage. Does anyone know where I can buy an OEM water pump beside from the dealer?
Thanks.
glvu is offline   Reply With Quote
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
Water Pump being replaced... Rental Car! slothman86 DIY / Maintenance / Service 12 08-11-2010 04:14 AM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
