Old 05-08-2011, 02:38 AM   #1
Yay
Drives: Yaris
whats the best suspension setup for a yaris rallyX?
looking to setup a yaris for rallyX and DD. what suspension is best?
Coilovers or struts/springs?
Im completely confused which is better....
Yay is offline   Reply With Quote
Old 05-08-2011, 03:28 AM   #2
I'm going to say a long travel custom coilover set up is your best bet. Try to find the member here who actually rally's his Yaris/Echo for more information on custom coilovers since he has had some made for his car.
Old 05-08-2011, 10:59 PM   #3
EPyarisdriver
...or Vegas for short
EPyarisdriver's Avatar
Drives: 2010 Toyota Yaris 3door LB
fully adjustable coilovers with all the arms and links should work wonders
EPyarisdriver is offline   Reply With Quote
Old 05-09-2011, 01:34 PM   #4
^ keep in mind that the OP has said BOTH rally and DD.
It's also a double post.
Old 05-09-2011, 04:19 PM   #5
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Stock would work best for dirt and DD . From October to February 90 % of my driving (Yaris) is on dirt . I usually put my stock shocks and springs back on b/c they allow the Yaris to maintain its attitude (level) over rough terrain. The stock shocks will absorb more bumps and won't violently pitch the car and your kidneys won't take a beating as much . The best reason to use stocks is that there are plenty of slightly used shocks here on this site for cheap . I have 3 extra sets and none of the have more than 20 K miles ( One of my sets has less than 5 miles on them ) .
Personally if I were to RallyX , I would buy another set of shocks and all the components that go with it . ( top mounting plate ??? ($108 x2 ) , bumpstops , rubber boots etc. etc. ) .Pre assemble everything that way you could make changing shocks/springs a 15-20 min affair . Also if they are legal , I would check into some ATV tires ( Like CTScott ) .
Garm you should try selling shocks this way . By that I mean already pre assembled . That way your customers would have an easier/faster time installing . Sure it would be more expensive , but they would not have to spend 30-60 mins compressing springs and transferring all the other components .
Old 05-10-2011, 11:56 AM   #6
^ That's not a bad idea. With a UPS label so they could return the same parts from their cars when they are done.
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 11:31 AM
