Old 02-07-2011, 10:21 AM   #1
nOmi_89
Drives: 2007 Toyota Yaris
Red face stock JDM head unit ND3T-W54
i want to know can i connect amp with it ??? i dunno where to plug amp leads :/
if yes where i can plug it :P
here are some pictures plz help me :P
nOmi_89 is offline   Reply With Quote
Old 02-07-2011, 11:36 AM   #2
Of all of the Toyota documents that I have on audio, none shows the pinout of all of those connectors. The bottom row, except for the center, is shown in the image below. In a worst case, you can use an amp that takes high level inputs.
Old 02-07-2011, 11:47 AM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Naomi which connectors actually go into the Radio ? Take a picture of them. Pretty sure it's the CN500 pin view. Ctscott is there a harness to where you wouldn't have to splice into the factory wire harness, maybe one that flips the harness around and has leads coming out of the harness.
You're going to need a Line Output Converter (Hi-Lo Adapter)(LOC) Which will require you to cut into the Rear 6x9 speakers, and you'll need to run a remote wire, which will come off the Radio Ignition. I'd check if they have another wire harness that will help you not have too cut into the radio harness, but if you must.
Radio Ignition- For the amp remote wire.
LR-For LOC
RR-For Loc
Old 02-08-2011, 05:45 AM   #4
nOmi_89
Wink
hope i got the best shots :)
Green+Red running thru amp = REMO wire,
Grey Wires with RED+WHITE endx = LINE INPUT running thru AMp need to be plugged in the HU...but dunno which One is used for both respectively...
*(One RED WIRE is for the battery +ve and
One RED WIRE is Ground -VE)*
sorry for my bad english..
Old 02-08-2011, 06:36 PM   #5
_S7V7N_
_S7V7N_'s Avatar
What gauge wire did you use for your Amp ? I'm looking at your wiring, looks different, imma look at it some more later on.
Get some connectors buddy, make your life a whole lot easier .
Old 02-09-2011, 05:44 AM   #6
nOmi_89
i actually dont remember what's the gauge...:/
yup i'll :) once i get to know which switch is used for RCA output for amp in head unit than i'll install connectors and just enjoy boom chika wawow :P
can u notify which empty switch is used for RCA output in this head unit :/ im confused
Old 02-09-2011, 10:54 AM   #7
_S7V7N_
_S7V7N_'s Avatar
Need something like this (LOC) Line output converter. It connects to your Rear speakers and has the connects for your RCA's .
Old 02-10-2011, 03:55 PM   #8
nOmi_89
Talking
hey i got one from pioneer :)
i've connected to the speaker wires :P
thnx for all ur guidance :)
but um some of my fuse died hehe :P
can u guide me which one to check ??
under the drawer dash or or the one in the engine bay area :P
Old 02-10-2011, 11:39 PM   #9
_S7V7N_
_S7V7N_'s Avatar
Do your dome lights work ? Radio ? Door locks ? What works and what doesn't ? best thing to do is get a Digital multi meter or Light tester and check your fuses. Light tester is going to be the easiest way, you touch the lead to the fuse and if it lights the fuse is good, thing is you need to touch both sides of the fuse.
Old 02-11-2011, 07:51 PM   #10
nOmi_89
thing is when i connected rem wire :p some of the fuse died :p my friend checked it,he said the parking lite are getting sparked somewhere that's why the fuse are dying :P
later,
my retract mirrors died,headlights gone,interior lites gone,brake pedal shifter for gear gone,radio gone,brake lights and camera too :P
than i replaced some of the 10 amperre fuses with good ones,
now everything works except the parking lites,and radio lites,and rear camera :P and later i got it checked from a auto electrician he said i'll charge you 1000 bucks its around 12$ US.
though i asked him whats the prob atleast lemme know why it is killing my fuses he said i won't tell you i'll fix you up and just charge you 1000 bucks :O
i've that light tester :D and multi meter too :p
i want to know what would be the fault In ur opinion :/ where should i take the start...i dont want to give my money to that bad guy !!!
Old 02-13-2011, 11:50 PM   #11
_S7V7N_
_S7V7N_'s Avatar
Did you check the fuses under the hood ?
Old 02-14-2011, 04:09 PM   #12
nOmi_89
Yup i did :)
all fixed now :D just changed some faulty fuses with new ones and now im good to go Yays :] everything is now perfectly working i'm happy :) thanks for your help and guidance
Old 02-14-2011, 11:10 PM   #13
_S7V7N_
_S7V7N_'s Avatar
Cool deal man, take pics of the system.
Old 02-15-2011, 10:08 AM   #14
nOmi_89
i'll soon upload some of the pics and video too :) now i just want to change my existing lasani enclosure to fiber glass enclosure with some l.e.d's on it :P i think it will look cool eh B")
Old 05-11-2011, 03:33 AM   #15
yasirrafiq786
Drives: Toyota Vitz 2004
@nomi--------hey that black wire coming out from the blue connector..is it for adding auxiliary input..cuz i want to add one to my nd3t-w54 ...can u please help as which connectors and wires are required ?
yasirrafiq786 is offline   Reply With Quote
Old 06-02-2011, 02:08 PM   #16
nOmi_89
um i think it's the main RADIO 12v input...
auxiliary or not..sorry bro it wasn't mentioned there...but i think it is what u said :)
Head Unit Install mannon In Car Entertainment + Electronics (audio / video / alarm) 9 08-14-2009 01:18 AM
Feeler: Pioneer AVH-6850DVD 2-DIN head unit + extras eTiMaGo Items for Sale by private party 19 08-07-2009 09:49 AM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
Stock Head Unit from '07 Sedan Venom Items for Sale by private party 5 01-19-2007 08:27 PM
installed head unit... punch In Car Entertainment + Electronics (audio / video / alarm) 16 06-29-2006 12:06 AM
