Old 01-05-2011, 08:24 PM   #1
rep1158
Drives: 2010 yaris 3 door stick
wheel bearings?
I have a Yaris with only 31,000 miles. I have had a loud noise coming from rear of car. took it mechanic said it it sounds like bad wheel bearings? really? i thought bearings lasted a lot longer. anyone else have this problem of loud, droning rear end noise?
rick
rep1158 is offline   Reply With Quote
Old 01-05-2011, 08:52 PM   #2
41magmag41
Drives: Loaded 2007 mica silver sedan
If you bought the car new take it back to the dealer, should be covered under the 3 yr 36000 mile warranty.
41magmag41 is offline   Reply With Quote
Old 01-05-2011, 09:36 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
^what he said.. also.. check for chopped out tires. has it ever been in a wreck?
Old 01-06-2011, 10:06 AM   #4
41magmag41
I'm ready to roll over 95000 on my 2007 and the only problem I had was the replacement of the ABS wheel sensors and wiring harness on the rear wheels, under warranty. The car is almost flawless in its performance and all. I'm surprised at all the problems that seem to be cropping up. My yaris has been the least expensive car I have ever owned and with gas prices starting to spike again I suspect that will continue. Let us know if your dealer takes care of it.
Old 01-11-2011, 08:10 PM   #5
rep1158
LR wheel bearing was replaced yesterday. Covered under warranty by 4000 miles whew! woulda been 500 bucks. Isnt that too soon for a wheel bearing to fail? jeez its a toyota!
Old 01-11-2011, 08:16 PM   #6
rep1158
I still have my 2001 echo now has 232,000 miles only problem cat con at 230,000
Old 01-11-2011, 08:24 PM   #7
sickpuppy1
Drives: 2010 Yaris Sedan
Yeah, it seems aweful soon for it to fail, but if they thought the car was perfect you wouldnt need a warranty at all. Stuff happens. I wouldnt stress over it. They make many many millions of bearing and some are gonna fail.Your just the lucky owner who got one.
Old 05-12-2011, 02:49 AM   #8
armandjones
Drives: N/A
Originally Posted by rep1158 View Post
I have a Yaris with only 31,000 miles. I have had a loud noise coming from rear of car. took it mechanic said it it sounds like bad wheel bearing? really? i thought bearings lasted a lot longer. anyone else have this problem of loud, droning rear end noise?
rick
Last night I noticed while driving this sound that gets louder at 60mph( the peak of the sound). You will start to hear this sound at about 35-40mph then it gets a little quieter around 85mph then it starts getting louder again. The sound seems to be a droning/humming noise. Change in pitch goes along as the speed changes... Could this be a problem in the wheel bearing??
armandjones is offline   Reply With Quote
Old 05-12-2011, 02:43 PM   #9
RedRide
RedRide's Avatar
It could be. Either that or a tire.
BTW/FWIW.....
Yes bearings last much longer now now that they did in the past.
However, you can still get a defective one or one that was improperly installed.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
new wheel? Nekofelin DIY / Maintenance / Service 1 08-10-2010 03:37 PM
2007 3 door 350000 miles eats wheel bearings! webfeet69 General Yaris / Vitz Discussion 23 12-15-2009 09:20 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
