![]() Drives: 2007 Toyota Yaris HB Join Date: May 2011
took it to autozone, but we can't determine the cold cranking amps on the battery. i have a 2007 yaris hb, since 2006 (about 105k miles on it). the car starts, the radio runs, the lights work fine, but the battery light is on (red - which indicates to go to dealer - which is closed today, of course). how can the light be on but the car runs fine? does anyone know the cc amps on the original battery? not in manual, on their website or anywhere! amazing, i've found the one thing google can't find!
thanks... |
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
normally, that light only comes on when one of three things is bad... target the battery, should be ~500cca IIRC... the second option is to check the alternator... third is to check your battery connections for corrosion... one other possibility, that autozone people might miss, is the serpentine belt there?
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
Maybe your alternator is having a problem.
Only Happy When it Rains
i didn't even know there was a battery light. That is just weird.
Colin Chapman disciple |
ekodrvr
all cars that i have ever come across have one... comes on when you first turn the car on, then turns off when the alt. picks up...
There's a known/common problem with 07-08's with the voltage regulator within the alternator corroding and casing the light to come on.
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
#8 | |
ekodrvr
go with scott's answer for the time being, and if that is not it, then we follow the trouble tree...
i dont plan to drive it anymore today...and my mechanic, thankfully, is half block away. i will have to go first thing in AM. even though autozone does free testing, i'm afraid to drive it back there (a couple miles away) and have it conk out on me.
ekodrvr
i would mention the TSB about the voltage regulator to the mechanic... might save him some time...
i also plan to ask him why this wasn't seen (if it is indeed corrosion) when i had my 100k tune up
He would only have seen it if he completely disassembled the alternator. There's a thread on here where I posted pictures of one completely disassembled.
#13 | |
i'll report back in the afternoon with any findings...i hope i can drive it to work- shoot! |
I've been dealing with this for nearly 3 years with my '06.
Whenever there is a heavy rainfall, or very dense fog, my battery light comes on. It willl always go out again when conditions dry up. I have a spare alternator on stand-by just waiting for the day the voltage regulator finally gives up for good. Had the spare for almost a year now but the original just wont die. BTW, is your light on solid, or does it flicker? Mine flilckers. If it is on solid, then you may actually have another issue other than the regulator.
![]() Drives: Polar White Liftback Join Date: Dec 2010
I have the same car and the same issue. I'm pretty certain that it's the Voltage Regulator. Can anyone recommend a good site to order from?
| Tags |
| cold cranking amps, yaris 2007 |
| Yaris sedan fog light bezels | SimTronik | Willing to Buy by private party | 0 | 10-01-2010 04:49 PM |
| Rear fog light for US '08 3Door Yaris (stick shift9 | Stefan | DIY / Maintenance / Service | 21 | 04-21-2010 04:30 PM |
| wtb: drivers side tail light for 08 liftback yaris | jjd | Willing to Buy by private party | 3 | 11-29-2008 03:12 PM |
