Old 06-06-2011, 08:05 AM   #1
rossman
Drives: 2006 YARIS RS
Squealing Belt
I just got my belt and water pump replaced. Since that my belt has been squeeling. I had it tightened by my mechnic but he doesnt want to over tighten it and blow the pump.
The belt seems to squeek when I start the car, then it stops. It has just recently started squeeling when I am stopped at a light.
Any suggestions?....would applying belt dressing help prevent the belt from slipping?
rossman is offline   Reply With Quote
Old 06-06-2011, 09:12 AM   #2
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
no warranty on that new belt??? even if its autoparts store im sure it has some sort of warranty....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 06-06-2011, 02:36 PM   #3
swidd
Drives: Yaris HB
why don't you tighten it yourself? Unless you are super strong or use a super size pry bar, I don't think you can over tighten it. Just don't put a bar against the oil valve thingy. Put it against the engine mount on the side... took me a while to figure out how it would fit in there to provide proper pressure on the alternator...
I got squeaky sounds at 85,000 miles, and figured I'd replace the belt. So I did it myself, and still had squeaking after replacement. So I tightened it some more, and now I have no bad sounds at all. The condition of the old belt was actually not bad at all... small cracks, no major wear, could've kept going to 100,000 or longer.
I think the manual says 7-8mm when installing, 11-13mm deflection after running for 5 minutes... That's not much really. + I think the belt stretches a little after 5 minutes of running also.
Old 06-06-2011, 05:52 PM   #4
RedRide
RedRide's Avatar
First off, your mechanic is to be commended for not wanting to overtighten the belt.
A new belt should not squeal if everything is lined up and tightened properly.
However, as pointed out a new belt can stretch a bit when new. So, I would check to make shure it is tightened properly
Old 01-31-2012, 12:52 AM   #5
aprilnroberts
Do you think a dying battery would affect the belt squeak? I was told that with the voltage being low that might be putting a load on the alternator, causing the belt to squeak.
whats your thoughts?
aprilnroberts is offline   Reply With Quote
Old 01-31-2012, 09:36 AM   #6
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
just tighten it bit by bit until squeeling stops. i always thought if it squeels its loose still. best to do it in winter time.
Old 01-31-2012, 11:44 AM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
sounds like the belt has stretched. this is why I HATE dayco and driverite belts. They are like rubber bands.
Belt dressing is really just used as a diagnosis. If the squeel goes away when you spray it, then its the belt, the squeel will come back after a bit. (used mostly when you have a small consistant squeel that is hard to tell the difference between a squeel and a bearing).
I agree with most here, just tighten it up some more.
-Derrick-
Old 01-31-2012, 01:58 PM   #8
Geoff Peace
Drives: Yaris 1.33 litre 2011
Apply firm thum pressure midway on the longest run of the belt. It should deflect 8 to 9mm. If greater it needs tightening. If OK do not tighten any more it will ruin the water pump bearing, a new, quality belt is needed, the pulleys cleaned and the belt tensioned correctly.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 01-31-2012, 01:58 PM   #9
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
I had same problem after replacing belt and water pump from toyota dealer I had to replaced with new belt , my other belt had less then 5k miles on it. Problem fixed :)
yaris4062007 is offline   Reply With Quote
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
squeaky belt TickleTimeTim DIY / Maintenance / Service 14 03-16-2011 11:49 PM
Altenator Belt Broken After Replaced by Toyota Yaris_guy DIY / Maintenance / Service 12 01-18-2011 09:14 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
