#1909 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
i'm onto a good tank
118.9miles when the first bar went off...i'm usually in the 90s
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#1910 |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
I filled-up my tank this morning... click to click with Shell ethanol gas on the same pump as a couple weeks ago. I'm starting to like Shell gas
![]() Gas Tank mile increments (ethanol gas used): 1st Bar drop (8/8) > 135 mi (135) 2nd Bar drop (7/8) > 60 mi (195) 3rd Bar drop (3/4) > 55 mi (250) 4th Bar drop (5/8) > 60mi (310) 5th Bar drop (1/2) > 60 mi (370) 6th Bar drop (3/8) > 65 mi (435) 7th Bar drop (1/4) > 75 mi (510) 8th Bar drop (1/8) > 0 mi (510) Tank total : 510 miles Fuel used: 9.666 gallons MPG: 52.762 Cheers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
#1911 |
"LibertyRides!"
^ Correction! I got confused. It was two different brands. Exxon was the last fill... the fill prior was Shell. Shell fill-up this this morning. I'm filling with shell after this tank on the same pump.
Cheers!
#1912 |
Obsessed with 1.5L
i was an exxon man cuz i had a very convenient one on the way to work, but it shut down, so i go to shell now also...
my 2nd bar went out at 205.7 & my 3rd 281.3
#1913 | |
"LibertyRides!"
Cheers!
#1914 |
Obsessed with 1.5L
4th bar- 331.6
5th bar- 395.4 6th bar-475.7 filled up at 503.9, used 9.355 gallons 53.86 MPG! that was with A/C use
#1915 |
Budget Buster
Very Nice, malibuguy.
With AC running during our Maryland heat wave, I pulled 50 mpg out of my '07 ATX sedan. I ran 545 miles on the tank. 10.9 gallon fill. |
#1916 |
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
Just had by best tank yet. An even 45.0 MPG. I think that's the best I can do.
#1917 |
#1918 |
Driving pretty hard this tank (smashing it around town and on the freeway, shifting much later than I normally shift, etc), and some AC usage. SGII is reading 36.1 mpg for my afe (average fuel economy). I set the SGII to read a little worse than what it actually is, so I'm thinking it's really ~37 mpg.
#1919 |
![]() ![]() ![]() Drives: 2010 Yaris "5-door" Join Date: Mar 2009
I just broke 50 for the first time this weekend. Two round trips from Hilo across the summit of Kilauea and back, plus lots of noodling around the Kilauea summit and Ka'u Desert roads. About 50 stops (engine off/on) during that noodling, as well. (150 miles total) :D
#1920 |
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
for an auto transmish will putting the car into neutral and coasting to a stop save a little gas ive always done this maybe not all the time but most of the time (i havent searched anything on this so i dont know)
#1921 |
If you know what you're doing it can save fuel in the right situations, but rolling in neutral with an automatic transmission could potentially also put you in trouble if the engine stalls while you're coasting. More of a problem with a heavy SUV (been there, done that) than a Yaris, but it's something to keep in mind.
#1922 |
Obsessed with 1.5L
when your in neutral you don't get fuel cut off
#1923 |
yeah i didnt say "get fuel cut off" i said to save a little but i guess thats how you interpreted that thanks great job!
#1924 |
Obsessed with 1.5L
51.22mpg last tank with a/c
#1925 |
Got 41.69 m.p.g. calculated . This is a '08 base model sedan w/ auto . The ECO showed 40.9 , have it set lower . Tires set at 34.5 and 87 with 10% ethanol .
#1926 |
But you DO conserve your hard-earned momentum.
