Old 06-14-2011, 01:00 PM   #19
33OH
Drives: '08 Yaris
Still impressive numbers - keep it up! I drive through the Appalachians each day to/from work and am averaging about 45 per tank if I keep the A/C off. :)
Old 06-18-2011, 07:30 PM   #20
roadrunner
Yaris Hypermiler
roadrunner's Avatar
Drives: 2007 Silver Liftback
To Idahotom............
What tires are you running on and at what pressure?
roadrunner is offline   Reply With Quote
Old 06-19-2011, 07:45 PM   #21
Idahotom
Drives: 2008 5 sp. LB
I THINK they are the stock tires, Goodyears Eagles, they came with it when I bought it used, (an 'O8 with 54 k miles.) They suck in the winter, I know that, but as I have to have 4x4 anyway, I revert back to the good old '89 Toyota All Trac, which now can rest all spring summer and fall while the Yaris gets a workout. Decent tread left, safe and legal anyway, but I'm looking forward to them being replaced with something better, rolling resistance wise they seem OK anyway.
I run them at 44 psi. No spare, jack, rear carpet and parcel cover thing, rear seat, and a small dog. I don't allow excess crap to build up, as I have that 1,000' climb every day.
Idahotom is offline   Reply With Quote
Old 06-19-2011, 09:48 PM   #22
roadrunner
Yaris Hypermiler
roadrunner's Avatar
LRR tires to get for the Yaris
When you do replace your Yaris tires, consider the Michelin Primacy MXV4.
An excellent tire for LRR, per TireRack and Consumers Reports. They are what I am putting on my Yaris this fall. I am now running on LRR Goodyear Integrity tires, which are ok, but nothing great. Have 5/32 on two, and 6/32 on the other two.
Old 06-20-2011, 12:20 AM   #23
Idahotom
I'll make a note of that, I've always liked Michelin tires anyway. Thanks
Old 06-26-2011, 01:31 PM   #24
charles nelson
Drives: red Liftback
I read a hyper-miler boast that he puts his AT Yaris in neutral while descending hills. A Toyota mechanic told me that the best method was let the AT do the coasting...the computer will not shut off the injectors if in neutral! If the AT is in drive and coasting...the computer will completely shut off the injectors...
charles nelson is offline   Reply With Quote
Old 06-26-2011, 01:43 PM   #25
nope1590
Drives: 07 yaris 3 door manual
It really depends on the situation. You are referring to DFCO which is covered extensively in other threads. DFCO and neutral coasting both have advantages. If I am looking to gain speed downhill, coasting is better because I can accelerate for free while only using the gas of idling. If I am already at my target speed, would need to use brakes, or slow down (stop light, tight turn, etc), DFCO is likely the better option because it will save on gas and brakes.
07 hatchback:
lifetime: 84582 miles, 41.172 mpg
last 12 months: 16795 miles, 43.961 mpg
best full tank: 503 miles on 10.153 gal, 49.54 mpg
nope1590 is offline   Reply With Quote
Old 06-29-2011, 04:31 PM   #26
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
And your car will slow down faster - what us old people call "engine braking", not coasting. Only really useful if you want to be slowing down or holding back your speed while going downhill. (works super on long descents)
However I would not casually put an *automatic* transmission in neutral, IMHO. Don't trust automatics.
bkrownd is offline   Reply With Quote
Old 10-04-2011, 08:34 PM   #27
theredone
Drives: 2011 Yaris Sedan
totally agreed. if that was the way we perceived what MPG actually means then all car manufacturers would say their models got 50+ MPG at the least!
Originally Posted by mryaris View Post
I all honesty, it really doesn't matter what your single trip mileage is......get back to us when you average 50+ MPG's over an entire tank. That would be far more impressive.
I'm not hating......it's just that there are so many variables in short trips that the mileage figures get skewed to the point where they become worthless in evaluating fuel economy over the long run.
theredone is offline   Reply With Quote
Old 10-06-2011, 08:41 AM   #28
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
I got 48 mpg once on my trip back home from work 35miles drove about 50 and took the car out of gear down the hills did it just to see how good it could do.I have got 46mpg's on a full tank a couple times just driving about 50
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 10-06-2011, 04:48 PM   #29
STC
"LibertyRides!"
STC's Avatar
I get upper 40's to lower 50's consistently. I drive 40 to 50 MPH with 70% to 80% rural country roads.
Winter gas must be here in PA now! I'm getting 46-47 MPG...
Cheers!
~ Mark ~
Old 11-10-2011, 07:15 PM   #30
The Sin
Drives: 2010 Yaris Sedan
I think MPGs should always be based on a full tank of gas. I always fill up then drive till the gas gauage blinks. I know I still have at least 50 miles to find a gas station.
The Sin is offline   Reply With Quote
Broke 50 MPG STC Fuel Economy Forum 71 12-13-2010 02:04 PM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 01:15 PM
Finally broke 40 mpg brg88tx Fuel Economy Forum 5 07-16-2010 09:34 AM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 12:49 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
