Old 07-10-2011, 04:22 PM   #343
Originally Posted by i-trans View Post
the switchs seem to be okay, no pulse when i push button.
i fugure that the problem are my cc clutch switch...
if my cc clutch switch are not okay, the cc are not functionnal.
i have try with the jumper in the fusebox, and unfortunately i have the same result...
i really don't know what is my cc problem, but i want to resolve that soon!
The only way to tell if the switches are bouncing is with an oscilloscope. A voltmeter is too slow.
Also, are you absolutely sure that you are on the correct pin on the ECM?
Old 07-10-2011, 04:38 PM   #344
i-trans
Drives: yaris liftback 2007
yes!
my connector was on the pin 40, i have make a re-check, and it was on the good pin.
For the switch, i have tested at this time with 14 switchs, buy at different store.
i have tested the 4 switchs mode, and the 2 switchs mode.
Actually i have 2 switch untested, i try these 2 switch after the lunch.
If the test are not okay, i pass an order for the stalk, or i pass an order for to momentary switch on an internet store....
i-trans is offline   Reply With Quote
Old 07-10-2011, 08:57 PM   #345
i-trans
Thumbs down
i have try my last switchs, and nothing new...no cruise control!
on my first switch i have 12,35volts.
when i push on, i have 0volts.
on the second switch i have 8,35volts.
when i push on this second switch i have 0volts.
i have 2 resistors ( 1x240 and 1x390 in serie ).
what are the best way to test my cruise control clutch switch?
i suppose that is my problem. (i have try with the jumper but, no result)
i have take a read of this 2 wires (in the fusebox, and i have no read (0volts)
when i push the clutch, i have no read ...)
if i read the white wire behind the puple wire, with the other blue wire, in diagonal i have a read of 12,33 volts.
I suppose that my blue wire behind the purple wire, are no voltage on in.
Old 07-10-2011, 09:20 PM   #346
That looks fine for a test setup. Snap a pic of your clutch switch wiring at the fuse box.
Old 07-10-2011, 09:42 PM   #347
i-trans
this is my clutch switch wiring in the fusebox
Old 07-10-2011, 09:51 PM   #348
You're in the right place. The blue wire needs to have +12V to it in order for cruise to be enabled.
Old 07-10-2011, 10:09 PM   #349
i-trans
the blue wire have +12v when i release the clutch in link with the white wire?
because i don't have any power on my clutch switch.
my wire are clutch switch +/- to fusebox (white and blue wires )
Old 07-10-2011, 10:14 PM   #350
Correct - When the clutch is not pressed the blue gets 12V from the white and when it is pressed it opens and the blue has 0V.
Old 07-10-2011, 10:20 PM   #351
i-trans
and this cruise control have a fuse anywhere, in case of shortcut ??
what's happen if utilise N.C switch for testing purpose?
in exemple the first switch are N.C (pin 40 to this switch) , and for the second switch i utilize an N.O switch?
the n.c switch when i push on it its "ON" when i repress on it its "off".
and the second switch its "set"
Old 07-10-2011, 10:26 PM   #352
No fuse - This is just an analog input to the ECM.
A NC switch won't work. The ECM expects to see the input float and then get pulled down to a specific voltage range for it to register. I have reverse engineered the Toyota diagnostics CAN Bus comm to read the cruise control switch state from the ECM, so I can watch how the ECM responds to the inputs.
Have you measured your resistors to see exactly what they read resistance wise. Sometimes you can get a batch that are really at the end of their tolerance band.
Old 07-10-2011, 10:29 PM   #353
i-trans
i don't know what is the way to test resistors...
12v on a side of the resistor and read the other side?
Old 07-10-2011, 10:32 PM   #354
Resistance setting on the multimeter. Measure with no voltage applied.
Old 07-17-2011, 03:49 PM   #355
i-trans
Thumbs up
My problem was resolved!!!
My cruise control are fully functionnal!!!
My problem was my resistor....
on the package it was write 390 ohm 1/4 watt, but in reality it was 390k Ohm 1/4 watts...
Thanks you CTScott for you're help!
Old 09-27-2011, 05:14 PM   #356
rob1005
Drives: Yaris 5DR
I just purchased the clutch switch from Toyota but it did not include any connector or wires. It just has two prongs. How would I go about attaching two wires to the prongs?
Toyota also gave me screws which are too big for the cruise stalk. Which screws do I need?
Thanks for all your help.
rob1005 is offline   Reply With Quote
Old 09-27-2011, 08:31 PM   #357
On the clutch switched that I ship to people with 06-08's, I solder wires to the two pins and then individually heat shrink them, and then heat shrink over both as a strain relief. You could also use some very small female spade terminals, if you are not comfortable with soldering to them.
The screws are M5-.80
Old 09-27-2011, 08:59 PM   #358
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Is there a DIY on how to remove the steering wheel and the airnag ?
Interior:ALL red, black roof
Old 09-27-2011, 09:02 PM   #359
Yes. My complete DIY has it:
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 09-27-2011, 09:15 PM   #360
packetrace
packetrace's Avatar
So...I unscrew the 2 side screw..and I pull the whole steering wheel...and It will pop off ?
OBVIOUSLY i disconnect the battery hahaha!
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
