Old 03-04-2007, 12:11 PM   #1
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
would this do?
i was looking for a retro look for my yaris, i always liked the wantanabe's, and now konig has reproduced them, the konig rewinds. would there be anything wrong with 15 x 7 0 offset. if not what would be the best tire size, 205/55?
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 03-04-2007, 05:36 PM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Off-set for a 7 inch wide wheel should be between 38mm and 45mm. Remember the lower the off-set the more the wheel is pushed outward. I have 38mm off-set and they are as wide as possible w/o hitting the fender.
PetersRedYaris is offline   Reply With Quote
Old 03-04-2007, 07:13 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
a +38 offset is perfect for a 7 inch wide wheel, it sits flush with the fender and just barly rubbs on the inside on full lock turns.... 205/55 or a 225/50 tire works.
here is a pic of my 225/50VR15's on my car
Old 03-04-2007, 08:12 PM   #4
PetersRedYaris
a +38 offset is perfect for a 7 inch wide wheel...
Agreed, that's what I just got and have no rubbing at all.
Old 03-06-2007, 10:13 AM   #5
sdmf
sdmf's Avatar
so 0 offset would be like, "hey look my car looks like a dune buggy now!" is what your saying. i guess that wont be a good choice of rim.
Old 03-07-2007, 10:15 AM   #6
PetersRedYaris
Exactly, they would stick out 38mm (about 1.49 inches) beyond your fender.
Old 03-07-2007, 11:16 PM   #7
JustYYaris
Drives: 2007 Blazing Blue Hatch M/T
Hey Black Yaris, love the wide looking tires on your ride. You said you have a minor rub on full lock with your 7 inch wide tires with a 38mm offset? I've looked at a lot of rims with a 40mm offset. Do you think with the extra 2 mm offset would elminate the minor rubbing on your car?
JustYYaris is offline   Reply With Quote
Old 03-08-2007, 08:16 AM   #8
sdmf
sdmf's Avatar
dreaming
I think Rewinds would be great! I also think Konig Remembers would be hot, too.
yea but i really dont wanna spend the money if im going to rub fender all day long. it will just be a dream i guess.
Old 03-08-2007, 10:23 AM   #9
PetersRedYaris
A higher offset means the wheel will be set furthur in which will increase rubbing at full lock. You would have to get less offset but 38mm is the least you can go without them sticking out to far and rubbing your fenders.
