Old 07-29-2011, 08:25 AM   #1
mmrdelany
Drives: 2009 5dr hatchback
new springs, abs light
Hey guys, just installed some new springs with OEM struts and the ABS suddenly came on. Any idea what this could be?
mmrdelany is offline   Reply With Quote
Old 07-29-2011, 08:55 AM   #2
You may have accidentally popped off one of the 4 ABS sensor connectors.
Old 07-29-2011, 12:16 PM   #3
Lil Abner
Drives: 2009 3dr LB Manual
Or you pulled a wire out in the rear. When changing the rear springs, it's very easy to un-bolt the struts, and let the axle just drop down. Unfortunately, it pulls on the ABS wires.
Old 07-29-2011, 12:23 PM   #4
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
I had this happen too. I had crimped the abs wire which broke it. I had to buy a new abs wire.
Old 07-29-2011, 12:30 PM   #5
mmrdelany
Thanks ill have to check that out. And the creeking noise from the new springs is all part of 'breaking it in'?
Old 07-29-2011, 12:49 PM   #6
^ Go drive the crap out of it, lots of turns, let them settle.
Old 07-29-2011, 01:23 PM   #7
mmrdelany
Oh good. So thats normal then? Was scared my tires would fall off or something. lol. its the MI springs btw :)
Old 07-29-2011, 08:21 PM   #8
mmrdelany
just took another look under the hood and i can see the strut poping out a 1cm or 2. could it be a tightening problem?
Old 07-29-2011, 08:24 PM   #9
Lil Abner
You mean the upper rubber bushing is away from the sheet metal? That's normal.
Old 07-30-2011, 12:15 PM   #10
^. Correct, 100% normal.
Make sure your lug nuts are tightened and torqued. That can cause creaking. I know I've driven off with hand tightened ones before.
Old 07-30-2011, 12:50 PM   #11
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
are you sure 1-2cm(1/2"-3/4")gap seems abit excessive i could see 1cm at most
OTA'sTOY is offline   Reply With Quote
Old 07-31-2011, 12:30 AM   #12
mmrdelany
Thanks guys. Springs were on backwards -.- The one post on MI.com got me confused lol. No creaking noises. Ride is unbelievably awesome. Just the ABS light is on. Anyone know where the sensor is located? pics?
Old 07-31-2011, 12:19 PM   #13
Revsson
Have a look at the Brake Control pdf, maybe that will help?
http://www.etimago.com/yaris/repairm...%20Control.pdf
or peruse the other sections of the Service Manual:
http://www.etimago.com/yaris/repairmanual/
Maybe you can take some pics while you are in there, too.
Old 07-31-2011, 12:37 PM   #14
If he's got the nut tightened properly, and he's using all the parts in the right order, then yes. This has been posted about over and over again, with pictures. Even a stock Yaris has a gap. It has to, because the strut moves around and changes angles as the car turns.
HELP / Spoiler connecting light SimTronik DIY / Maintenance / Service 4 11-02-2010 11:08 PM
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Parking Light Flash Output vs Hazard Light Output sex DIY / Maintenance / Service 2 11-03-2009 08:47 PM
Emergency brake light is on constantly AdeJong 03 DIY / Maintenance / Service 9 10-10-2009 09:32 PM
'09 Fog light replacement Mavix Cosmetic Modifications (Exterior/Interior) 5 10-07-2009 03:21 AM
