Old 07-31-2011, 03:54 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
New tune.....
I decided to hit up the 1/4 today to get an idea of what times to expect when I compete at Scion Exposed coming up. I did not want to deal with breaking axles today so I left my steelies on, holding the factory 185/60-15 all seasons . I still managed a 12.93 @120.1mph! 120mph trap speed is supercar territory, needless to say I am exstatic about that! Im fairly certain now that 11's is possible with slicks! This tune is still on pump gas running 27psi. We are going to play around with a E85 tune this week........
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 07-31-2011, 04:21 PM   #2
man that is AWESOME. That shows lots of power for the upper gears.
I gotta get out there, totally jealous.
Old 07-31-2011, 04:23 PM   #3
thepartsmancometh
Drives: '08 LB, '07 WRX
awesome! I'd be really interested to see what you can do on e85. A lot of the seriously built subaru guys run e85 (cheap, and you can make more power)
thepartsmancometh is offline   Reply With Quote
Old 07-31-2011, 04:53 PM   #4
I only opted out on E85 because it's difficult to get near me, and the storage issues.
Old 07-31-2011, 05:37 PM   #5
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Yea same situation here, closest station is 30 min away. We are using my car more for testing, gotten many inquiries about e85 tunes so I am going to be a guennie pig lol. I won't be running on the e85 map normally. I have to look at the Haltec manual, see If I can just wire in a switch to manually change maps. That would make life easier.
Ptuning.com
Old 07-31-2011, 10:09 PM   #6
thepartsmancometh
wish I had the bucks to do something like this, we have e85 EVERYWHERE here in Illinois. It's almost impossible to find uncut gas around here
Old 07-31-2011, 10:31 PM   #7
TURBO YARIS
Drives: Yaris
Attachment 43173
You dont need to convert to E85 (which will give you more power) you need to get your xA to hook! 120mph is for solid 11 second run! Nice run
TURBO YARIS is offline   Reply With Quote
Old 07-31-2011, 10:42 PM   #8
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Upgrade those axles and get those slicks on every time. That is a fast car right there.
Old 08-01-2011, 11:06 AM   #9
Viperoni
Drives: 2005 Toyota Echo
Trappin 120mph is pretty quick, sweet!
2006 Saturn Ion Redline
Old 08-01-2011, 12:31 PM   #10
MUSKOKA800
MUSKOKA800's Avatar
Watching the American LeMan's race last weekend the commentators mentioned that E85, which many teams run for the Michelin Green (environment) points, makes less HP than gasoline so those teams are allowed consessions (lower weight, increased tank size, or others) to make up for the power sacrificed.
I'm guessing E85 runs cooler (like alcohol) than gasoline which may be advantageous in a high boost turbo application???
Old 08-01-2011, 08:49 PM   #11
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I remember driving there for a time attack a while back.. all I saw was cornfields, so no suprise there lol.
Yes, the fuel itself is 85% ethanol, 15% gasoline. It is about 110 octane, and burns colder than race fuel. It is expected for coolant temperatures to be 20 degrees below normal with e85. on a boosted application around 400hp, a 50hp gain is not unheard of at the same boost compared to 93 octane. However I am running water meth now, so I don't expect 50hp . I would be happy with 25hp gain. I can understand why rules for LeMans would allow larger fuel tanks in cars running e85 , because about 30%more fuelling is needed to support an e85 tune.
Ptuning.com
Old 08-02-2011, 04:54 AM   #12
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
My roomies old RHD crx was tuned for E85. The shop did a dyno before and after. It was like 147whp with some N/A mods (cams, intake, exhaust, ex.). Then they tuned it with E85 and did another dyno afterward, it hit 181whp.
Only problem was we only have 1 gas station in our city that carries E85. The next closest one is 2 hours away and in another state.. lol
I say do it.. go for that switch so you can toggle a tune between E85 and 93.
Ecu tune help Beeno Performance Modifications 2 11-13-2010 02:36 PM
Is 30,000 miles time for a tune up? Yay LA DIY / Maintenance / Service 10 10-03-2010 11:12 AM
Micro Image Yaris tune cali yaris Forced Induction Forum 53 07-07-2010 10:27 AM
tune up?? any diy.?/ marcus DIY / Maintenance / Service 22 11-04-2009 04:37 AM
Tune Up Question? bestyaris DIY / Maintenance / Service 5 01-02-2007 09:09 PM
