Old 08-04-2011, 03:57 PM   #19
Originally Posted by weedtank View Post
If you have the the complete steering wheel with airbag, will it be a direct bolt on?
I haven't seen the airbag connectors on the 2011 TC yet, to know if it is a direct bolt on and plug and play.
Old 08-04-2011, 04:00 PM   #20
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
How about the older tC models?
weedtank is offline   Reply With Quote
Old 08-04-2011, 04:34 PM   #21
heeroyuy01195
Post count means nothing.
If I got my hands on the tc airbag cover, could I possibly swap it with the yaris airbag cover? In other words, could I use the tc steering wheel and airbag cover but use the yaris airbag? Or would I need the tc airbag and cover? I just don't like the idea of the yaris cover not fitting the tc wheel perfectly (bad case of OCD I guess).
Old 08-04-2011, 04:43 PM   #22
The older TC ones have the same connector, and from a quick search it looks like the 2011 does as well.
As for swapping guts under the cover, there's a thread on here where I show what is involved in doing so. I took apart a popped one, which has none of the danger associated with doing so with a live one.
Old 02-24-2012, 03:21 PM   #23
Originally Posted by TOLMACH View Post
Does anyone know if japanese steering wheel will fit the 2009 liftback (Canadian version)?
Thanks
http://injapan.ru/auction/x208512722.html
That would fit, but the airbag is missing. The airbag cover and the horn switch are there, but the airbag itself is not.
Old 02-24-2012, 03:30 PM   #24
Thank you!
I understand that if I buy this one,, that is gonna be sort of gambling whether my airbag fits it ((
You would have to transfer the airbag squib assembly over, since the cover is completely different. It would fit, but moving it over would be very difficult and dangerous.
Old 03-02-2012, 07:04 PM   #25
tk1971
tk1971's Avatar
I actually have a Scion TC leather steering wheel on Crashy. The Yaris airbag cover doesn't fit it perfectly, so ideally you would want the TC airbag:
I just cut a piece of hard rubber, lifted the bottom spoke leather cover of the TC steering wheel and glued it in. I then glued the leather onto the hard rubber.
I could have done a better job fitting it with my airbag, but I got lazy and eyeballed it. Looks like the spoke is now touching the airbag, but there's a small gap.
tk1971 is offline   Reply With Quote
Old 03-05-2012, 02:06 PM   #26
tk1971
tk1971's Avatar
Thanks, man
Is the leather glued to the plastic underneath ? Was is easy to lift the leather cover?
(Considering couple ideas)
With the wheel off the car, the leather easily peeled off. I did re-glue the leather onto the hard rubber underneath. I used industrial contact cement available at Home Depot / Lowes.
There's just not too much leather there to begin with on that steering wheel spoke, so I tried to straighten out the gap.
If you were to do some fitting beforehand, you can get it to look lots better than I did.
Good luck.
Old 03-06-2012, 03:20 PM   #27
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
i read somewhere on this forum, the new yaris steering wheel won't fit our model
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
