Old 10-15-2010, 12:14 PM   #163
metalshark
MetalShark
Drives: 2008 Yaris LB
Tach dreamer update: I've finished the 33 LED analog display installed in the display trim similar to my earlier BS2 tach. Those of you from the LA basin may have seen the only operational prototype of the gen 1 tach. I've finished the firmware (with the help of Prallax.com forum members) on a breadboard for a digital readout. It's running in my Yaris today. I'm changing the 4x7 segment display from red to green. I had a setback learning to solder surface mount chips for the analog display.
I'll have to do a version 1.1 layout before it's kit ready. I love the headrest video camera mount I found here. When success is apparent watch for the video coming soon to a forum near you.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 12-06-2010, 06:37 PM   #164
OTB
OTB's Avatar
Drives: 2zz MR-2 Spyder
Wiring question
A question for this installation....
Could you also tap the tach and illumination wires that plug into the main speedo panel? There is a tach signal even for cars without a tach display. I know becuase I plugged a canadian panel into an american liftback and the tach worked fine.
cheers
OTB is offline   Reply With Quote
Old 01-07-2011, 12:27 AM   #165
jrsyaris
Drives: 2007 toyota yaris
putting a stock cluster,w/tach in a 2007 HB.
i would like to put the instrument cluster w/ tach, in a us spec, 2007 hatch back.
will the cluster physically fit, and how much of the wiring to the cluster would
have to be re done? has any body tried this before? thanks for any help in this
area. bob smith, ohio
jrsyaris is offline   Reply With Quote
Old 01-07-2011, 06:37 AM   #166
It is plug and play, as long as you purchase one from a comparably equipped car (i.e. if you have ABS it has ABS, if you don't it shouldn't). There are many threads on here about people having done so, or desperately searching for one to do so. The hardest part is finding one, since so few Yaris in the US have had them.
Old 02-21-2011, 03:43 PM   #167
dumb0
dumb0's Avatar
Drives: '07 Yaris 3dr LB
Send a message via Yahoo to dumb0
hey guys! i just installed my tachometer yesterday!
special thanks to mr. CTSCOTT for the wiring suggestions!
will post pic soon. orayt!
next stop, suspensions! :))
Live, Laugh, DRIVE!
dumb0 is offline   Reply With Quote
Old 04-08-2011, 03:16 PM   #168
Ron Powley
Drives: Yaris lift back, red
Tach is important to me. Hearing aids, and excess road noise make it impossible to hear the little hum of the engine.
Ron Powley is offline   Reply With Quote
Old 04-09-2011, 04:07 PM   #169
Brianr4
Drives: 2008 Yaris 3dr Hatchback
RPM check
Just installed my tach and wanted to compare RPM's to make sure it is accurate.
2008 3dr, 5 sp manual.
Turning 3000 at 70 mph.
2500 at about 60.
Brianr4 is offline   Reply With Quote
Old 04-09-2011, 10:12 PM   #170
RedRide
RedRide's Avatar
That sounds right
Mine reads about 2800 @ 65mph in 5th
Yours is callibrated/configured properly for a 4 cylinder.
Old 04-10-2011, 11:09 AM   #171
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
Brainr4
There isn't much diff between the Auto and 5 speed, (I imagine thats why the epa guesses we'll get nearly the same) I'm running about the same "R's" with my auto...a drop to 3rd puts me at 4300+/- @ 70.
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 04-11-2011, 10:34 AM   #172
Brianr4
Thanks!
I didn't think I would be turning so much at 70mph.
If we had a 6 speed gas mileage would be close to the Prius.
Ha, I guess that is why they would never put a 6sp in the Yaris!
Old 07-21-2011, 10:00 PM   #173
Who_Is_SB
Who_Is_SB's Avatar
Drives: 2009 Yaris 3DR HB
Send a message via AIM to Who_Is_SB
Just installed my tach, 3 3/4" Glowshift Elite 10 Colour. Behind the steering wheel with full access to the glovebox behind it c:
[Taken with Nikon D3000 w/ 10.5mm Fisheye]
Who_Is_SB is offline   Reply With Quote
Old 08-04-2011, 02:18 AM   #174
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Followed this DIY, works fine. You can actually use any of the "top" row of the OBDII connector for ground.
Old 08-08-2011, 03:14 AM   #175
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
why would you though when there's a body ground right there
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 08-10-2011, 01:09 AM   #176
RedRide
RedRide's Avatar
Right where?
Old 08-10-2011, 01:48 AM   #177
KSIbucky
KSIbucky's Avatar
There's ground right by your left foot. read the diy. why would you want to ground to a obd2 rather than a factory ground point
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 08-11-2011, 07:43 PM   #178
RedRide
RedRide's Avatar
Yeah, behind the left kick panel (by your left foot) is where I grounded mine.
I did that out habit more or less as most all Toyotas have factory ground pont there.
However, the OBD2 is closser so why not use it?
Old 08-12-2011, 02:40 AM   #179
KSIbucky
KSIbucky's Avatar
The factory ground is better. Why tap into a wire thats a foot away from a ground point? The factory ground is exactly that a ground its not a obdii point it has a purpose use it.
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 08-12-2011, 09:08 PM   #180
RedRide
RedRide's Avatar
Not really, If something has a positive ground and can more than handel the current load imposed on it, that is all that is required or ever needed
A tach is a very low current draw item and the OBD2 ground is more than adequate.
Don't loose site of the fact that if you are getting the tach signal frome the OBD2 to begin with, it will also be good for the ground. All modern tachs use LED/low current lighting.
Otherwise, it would be like runninng a perfectly adequate 24ga wire for an item's positve and then, runing an 8ga wire for the ground for example. There would be simply no need for a 8ga ground.
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
US Yaris: Adding a tach? Thirty-Nine General Yaris / Vitz Discussion 159 04-05-2007 08:23 AM
