![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
is it possible to add A/C
Ok so I did some searching and didn't see anything, though i'm sure somebody will jump on me for this new post.
Does anybody know about this - I have an 08 sedan bare bones, no options, is it possible to add A/C to the car? or is this just too big of an undertaking? I looked at the 07 manual online and there are 60+ steps to getting to the A/C unit (looks like it's inside the car buried well within the dash). But then I thought about the Cruse threads where everything is already there. Any ideas if the internals are all there and you just need to add the hoses, compressor and electronic controls / relays? thanks in advance all |
Possible? Sure. Easy or cheap? Doubtful...
#3 | |
Everything for the AC is extra, so there are no "internals", other than the wiring. Check for the presence of the compressor connector between the alternator and the starter. If it isn't there, then you need the wiring harness.
Looking at the EPC, I don't see different "Wire, Engine Harness" main, #2 or #3 as having versions related to AC or no AC, so I have a feeling it's there.
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| Yaris A/C Efficiency | ArtS | General Yaris / Vitz Discussion | 7 | 06-19-2011 02:16 AM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
