![]() ![]() Drives: 09 yaris hb Join Date: Jul 2010
rattly clutch.. ?
howdy,
i've noticed my that when i'm driving around or even just revving and holding the revs at anything over 2000rpm with my foot off the clutch peddle, there's a slight rattle and over the last month its turned into a higher pitched rattle.. but if I rest my foot on the clutch peddle the sound disappears. If I press it down only 1cm or all the way the sound goes away. I've had a quick search for clutch rattles and gearbox rattles and couldn't find anything that sounds like my problem. Has anyone had this problem/annoying sound? Any idea what it could be? Maybe the lube on the gear selector/clutch cable in the engine bay might fix it? 09, 1.3L manual hatchback. |
![]() ![]() ![]() Drives: Yaris sedan Join Date: Apr 2011
This may be a spring on the clutch disc
They may become weak and begin rattly. Possible cause overheating of the clutch disc.
I like very much travel |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
Apparently this is a common complaint in the Echos. Replacing the clutch isn't cheap, either!
#4 | |
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 01:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
