![]() Drives: 2007 Toyota Yaris Join Date: Aug 2011
ECU Identificacion
Please help me out here. I need the ECU list for Toyota Yaris from 2007-2009 at least. I need to identify my ECM that was robbed and now polices haves it. They are asking me to proof that is mine. I know that for example first 5 digits like 37820 corresponds to Honda ECU's and the middle number that starts with always a "P" and the 2 digits forward tells the year, like "PM5," which indicates a 1988-1991 Honda Civic or CRX while. I need that kind of information for Toyota Yaris and can't find it online. Please if someone knows where to find this I will thank so much, this will save my car.
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
take vin to dealer and ask for price on ECM. you should get your part number right there....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
There is nothing on the outside that will equate the ECM with your specific car. The ECM is programmed with the car's VIN number though, so if one were to put it in a car and poll it with a Toyota TechStream tool one would see your car's VIN.
Identifying the car could be done with the part number. I just need the ECU online lists for Toyota yaris.
TRIM HUNTER
HMMM, guess your screwed seeing as there isn't any. pm me vin number and i'll help you out....
Based on your VIN, the EPC says that your car had either 89661-52G50 or 89661-52F11 as the ECM part number.
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
someone stole only ur ECM? y?
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| FS: Motec M4 Standalone ECU w/ Ignition Expander | Biggie™ | Items for Sale by private party | 6 | 10-20-2009 02:36 PM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
| DIY: Tricking ECU Throttle Body Relearning | gwasabi | DIY / Maintenance / Service | 2 | 04-03-2009 07:02 PM |
| Yaris has a learning ecu? | YogiYaris | Performance Modifications | 9 | 05-30-2007 07:03 PM |
