#37 |
Sorry for the delay everyone, ive been very busy with work, wedding plans n such.
so ive been to 2 track days since the rotor upgrade and about 2k miles street driving and everything is holding up great, no issues at all, i dont know if you can consider it an issue or not but finding 12.9 hardware to put in place of the stock caliper bracket bolts was not easy. M10x1.25x45 flanged bolts are not easy to find. The first track day was done on stock pads and i was pretty impressed. there is a very noticeable in stoping power and much less pedal effort to get the desired braking. after the frist track day my new pads finally arrived. stock replaced with hawk pads. second track day was even better with the new pads. it took a little getting used to braking so late for corners i found myself nearly stopping before i got to a corner off a high speed section. it now seems that i can hold off breaking 40ft or so closer to a corner than with the stock pads and rotors. overall this car just became alot more fun. |
#38 |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Sweet!!
#39 |
![]() Drives: Echo Join Date: Jun 2010
I read threw a few of the posts that are not Seth's and didnt see this mentioned. This would mean you can use a brake kit made for a honda as a full BBK... right?
Anyone know if yaris and Echo brakes are the same? |
#40 |
Camry Owner
OMG, I think I just had a minddumb after reading most of this stuff.
![]() I;m looking for a BBK for my Corolla, as well as my friend is for his Yaris, who sent me this thread. I HAVE to chime into this. I have nearly an IDENTICLE setup to this on my Camry. I've installed it on several other cars. Stock caliper, relocation bracket, Supra TT rotor. It;s track tested. And by track tested, my friend has done road racing on his local track with it. 300whp Camry. Not one issue. Couple others in Cali, same thing. My car can outbrake many sports cars. Not goign into the physics with it, as I see another member here did an amazing job at that already. :) ![]()
#41 |
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
Here is a short video on performance rotors from Stop Tech and Power Slot rotors, who also have BBKs for most cars. I'm going to use their rotors on my '87 Celica GTS racecar, with slotted rotors up front and drilled at the rear. Because I'm going to be using calipers and rotors from a '95 Celica at the front, I'll already have a thicker and beefier rotor, so slotted will work just fine. The rear is a solid disk, so drilled will disapate heat and moisture much better!
http://www.youtube.com/centricparts#p/a/u/2/_L_ev1iuGzg racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
#42 |
| one brake light out | xartrax | DIY / Maintenance / Service | 3 | 01-27-2011 12:40 PM |
| big brake kit | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-13-2007 01:44 PM |
| big brake kit | yrsdrgn | Performance Modifications | 17 | 02-20-2007 11:05 PM |
| cheap trd big brake kit *joke* | birdy | Off-topic / Other Cars / Everything else Discussions | 3 | 06-13-2006 12:04 AM |
