![]() Drives: Yaris 2003 Join Date: Apr 2010
Hi,
Could any of you tell me how easy is it to adjust the handbrake on 2003 Yaris. When I first pull up the handbrake it doesn’t hold the car sufficiently and if on a slight incline it begins to roll. I have to then pull the handbrake up to it’s highest possible point to have any effect. Is it possible to tighten the handbrake. Thanks for any advice Roth
Last edited by Roth5150; 09-12-2011 at 06:42 PM. Reason: Didn't say what Year of car |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
There's the bolt under the handbrake lever, you should see it connect to a steel wire ... If I'm not mistaken, u should tighten it clockwise ... And test it afterwards ..
| Unknown plug under handbrake | o.molina1 | DIY / Maintenance / Service | 1 | 01-29-2011 01:35 PM |
| how to break loose pulley bolt | yaris9876 | DIY / Maintenance / Service | 10 | 05-16-2010 01:55 PM |
| Had my brakes done....now handbrake is harder to pull. | captainm27 | General Yaris / Vitz Discussion | 7 | 05-10-2010 07:00 PM |
| Loose shifter knob | dvspindler | Cosmetic Modifications (Exterior/Interior) | 7 | 08-06-2009 04:07 PM |
| Auto trans : Drive to Park + Handbrake : was not in park... | Maxh91 | General Yaris / Vitz Discussion | 7 | 06-11-2009 06:37 PM |
