Old 09-14-2011, 04:24 PM   #37
Focus_Sh1ft
Focus_Sh1ft's Avatar
CTScott, just so you know - my crank signal is tapped. I tried to intercept it and the car wouldn't start. This make sense - the FIC only needs to see the crank signal, not manipulate it.
As for the MAF - that definitely is a problem (although I'm sure I don't need to be the one to tell you that lol).
On a side note: I'm bummed you didn't come down to Jersey for help Adrian. You could have delivered that kit I'm still hoping to buy from you
Old 09-14-2011, 04:33 PM   #38
So, your NE+ (pin 122 of the ECM) is tapped as well as the NE- (pin 121)?
Old 09-14-2011, 04:36 PM   #39
sorry to run this on two forums, but it helps everyone I think:
Boomslang:
Cps ne- is the crank timing ground. It is supposed to be spliced into, not intercepted. Same goes for the cam timing ground.
We worked with AEM on the CKP/CAM/timing ground wiring on the newer Toyotas back in 2007 before the FIC was readily available. We’ve made a couple thousand Toyota/Scion harnesses since.
MAF output is light green, same color as the extension portion of the harness, it blends right in.
Old 09-14-2011, 04:43 PM   #40
Focus_Sh1ft
If I remember correctly, I tapped the MAGI+ and MAGI- wires to crank + and crank ground respectively, and the MAGO wires (+ and -) were left unused.
EDIT: What Garm quoted makes perfect sense as well. Basically just try all three methods until you get one to work. I don't understand why intercepts didn't work for me but whatever - taps work.
Oh yeah and Adrian - I hate to say I told you so but... Well, I did.
Old 09-14-2011, 08:27 PM   #41
Brian
Brian's Avatar
This might explain my starting issue. I'll pull my harness this weekend and take some pics.
Old 09-14-2011, 08:43 PM   #42
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
How does the FIC retard timing if the crank signal isn't intercepted? Does it also intercept the 4 ignition signals?
Old 09-14-2011, 08:56 PM   #43
It only connects to the injectors, CAM, Crank, and MAF. There is no direct control over spark, just timing via intercept of the crank (if it is wired in intercept mode).
Old 09-14-2011, 09:11 PM   #44
Bluevitz-rs
That's what I thought. That's why I don't understand people's problems with it wired in series with the FIC.
Old 09-18-2011, 05:57 PM   #45
Focus_Sh1ft
I finally had a chance to double check my wiring today. It turns out I intercepted the positive crank wire, and tapped the negative. Same with the cams. I also verified ignition can, in fact, be adjusted.
Old 02-24-2012, 02:20 AM   #46
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
2007 Yaris Sedan
Custom T28 Turbo 7psi
underdrive crank pulley
15" stock steelies
winterforce tires
AEM F/IC
AEM UEGO Wideband
High Flow Cat
2.5" mandrel bent exhaust
MagnaFlow 6" canister universal high flow muffler
91 octane with STP octane boost
HKS Super Sequential BOV
No video at this time. Will record video after fuel pump is upgraded possibly within next 30-60 days.
Old 02-24-2012, 10:05 AM   #47
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
-Derrick-
Old 02-24-2012, 10:59 AM   #48
excellent!
What changed from all the "going lean at 5k" etc.?
Old 02-24-2012, 02:46 PM   #49
fnkngrv
fnkngrv's Avatar
excellent!
Well that is an interesting story. Apparently they had heat soaked the motor to the point that while on the dyno during his first pulls the car was going rish and then super lean at around 52-5400. During the 3 days he had my car he did 28 dyno pulls. On the evening before I came back to the shop he took the car out and did a road test. When he did that he was noticing that he was able to get to around 6100 before it would do the same thing. Alex wasn't surprised because of course a dyno is not the road. He made some final adjustments and didn't soak the motor as deeply and then took it out for another test drive immediately. He was still being able to run up to 6k. He also feels that I am actually around 180-185HP on the road. I picked up the car late yesterday afternoon and drove it the 420 miles home. The car ran great for the most part. I know that I have some work still left to be done to have it as close to perfect that an F/IC can get it. My plans are still to go with a stand alone down the road. The F/IC is merely a stepping stone. He said that he could not confirm for sure that once I upgrade my fuel system whether or not it will net more power, but he feels that it could because the car is still producing power when he lets off at the 5900/6000rpm point.
Old 02-24-2012, 03:56 PM   #50
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Nice! Glad it looks like you finally got the kinks worked out of it man. Have you done the new paintjob and all that jazz yet?
Old 02-24-2012, 04:11 PM   #51
fnkngrv
fnkngrv's Avatar
^ not yet. slated for End of March into April if all goes well.
Old 02-24-2012, 04:23 PM   #52
47_MasoN_47
Awesome, I'm looking forward to seeing that one when it's finished up.
BTW I bought a machine gun instead of a subwoofer, lol.
Old 02-24-2012, 08:03 PM   #53
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Fucking awesome. Damnit...i really want to build my turbo kit for the Yaris. But i have to finish the race car first.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-24-2012, 08:40 PM   #54
Zage Turbo Kit
Status: In Stock
Quantity On Hand: (1)
Just saying.
HKS turbo for mk1 yaris 1 litre 1SZ-FE nuttallacpw Items for Sale by private party 10 01-26-2011 05:03 PM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
