![]() Drives: scion xb Join Date: Dec 2010
Custom Intake manifold!
I just bought a corolla 2000 intake manifold with the flange made for the 1nz. Also adapted a corolla 2zz throttle body. Did some powder coating and mounted it today! had to improvise for the moment with the vacuum hoses but I will fix this tomorrow... right now I wanna test this! here are some of the pics.
result should be interesting - no-plenum design
2ZR swap. DO IT! Ask how!
What's the throttle body flange inner diameter? I've been thinking I want to try and fab up my own to get the full 1ZZ tb diameter instead of necking it down to stock.
Cool! Is this a one off or is someone making these?
thread should go in Performance Mods, no?
![]() ![]() Drives: 2008 hatchback Join Date: Sep 2011
Wow, drive by cable? Second Yaris I know that uses that!
I've got the 1zz throttle body, and my intake manifold is ground down to the diameter of that throttle body (big difference between a stock intake manifold and port matched btw) |
^ his "Drives:" is an xb so why wouldn't it have a throttle cable?
People here in Puerto Rico are doing it for the 1NZ.. I have seen a couple on a classifieds web page from here.. I bought it for 150 from a guy who claimed around 8hp on an aspirated motor. I felt more power just bolt on, but some A/F problems at idle the motor turns very lean so next week I'm off to the dyno to do a tune and see the numbers.
BTW how do I change this to performance mods??? Sorry noob here! |
#9 | |
I think its a little bit more than 2.25". Huge response when going WOT. If you want to do it you'll have to make a custom flange since the throttle is 4 bolts instead of 3. |
Crap, I knew there was a catch! I thought there were some drive-by-wire TBs with three bolts, but looks like only the cable driven ones have 3. Does it look like the end of the plenum could be cut off and re-welded with a new flange? The only pic I could find online was a side view that doesn't show the TB port.
Even if it doesn't make much power, it's sexy as hell; I'd rock that.
![]() ![]() ![]() Drives: Yaris sedan 10 std... Join Date: Aug 2010
Uff PR lo hace mejor a mi me venden.una en 50 pesos pero.hay q hacerle la chapa mas lo del trotel ... De q parte eres???
#13 | |
Yes you could cut were the throttle is bolted on and make a flange for the other throttle and weld it. It has the space to do it! Or you could use the throttle that comes with the manifold which is bigger than the 1nz. |
#14 |
From Mayaguez! 50 bucks sounds nice.. but the expensive part here is making the flange to make it fit in our motors, The guy who I bought it from said it cost him 100 to make the flange :/
#15 |
#16 |
The yaris uses electric throttle control (DBW), not a cable like the xB. There are plenty of 1.8L throttle bodies for the 4-bolt pattern with DBW, but none that I can find with the 3-bolt pattern and DBW.
#17 |
I see, well then you have to make a flange from 3 bolts to 4 bolts like I did. If you look at my first picture look at the spacer between my manifold and throttle. You'll need to make a flange that bolts to the 3 bolts of the manifold and on the opposite side of the flange put 4 studs(symmetrical to the throttle) in which you will bolt the new throttle. Wish I had the pictures of the flange so I can show you, but its pretty easy and I can to help you out with questions If you are going to do that.
#18 | |
Edit: I just picked up a manifold yesterday, and ordered a TB last night. The only thing I need to get this project rolling is the dimensions and layout of the cylinder head flange. Do you by chance know if the cylinder spacing is the same on the 1NZ and the 1ZZ? Last edited by CrankyOldMan; 10-14-2011 at 07:43 AM. |
| Custom Short Ram Air Intake Problem | laxsaint99 | DIY / Maintenance / Service | 10 | 04-27-2011 01:28 AM |
| Custom Intake manifold/w 1zz tb / direct port nitrous | blacksandiegovitz | Items for Sale by private party | 28 | 11-23-2010 08:57 PM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| My Custom Intake | RacerFreakXXX | DIY / Maintenance / Service | 7 | 12-21-2008 07:32 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
