#19 |
2ZR swap. DO IT! Ask how!
Ok, found some info on the 1ZZ.
* 87.5 mm cylinder spacing. * 41 x 413 mm runners I measured the flange on the manifold and found that the runner spacing is also 87.5 mm, and the ports are 35 x 52 mm elliptical. Update: I found some info on the 1NZ cylinder spacing: cylinder bore: 75mm cylinder wall thickness (between bores): 8mm cylinder pitch: 83mm That should make the header pitch 83mm as well. Now to figure out the opening dimensions and bolt locations... Last edited by CrankyOldMan; 10-15-2011 at 05:43 PM. |
#20 |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
Monchy huevon t dije q brega!!!!
Here's on a friends Yaris N/A 115whp ![]() Here's on a friends Yaris Turbo/Nos 305whp
I Drive a 129whp Yaris ;) |
#21 |
Maybe that type of manifold works better for boosted cars than N/A, I had a buddy of mine (with a B.Sc in ME, built an IM as a part of his schools Formula SAE team, and worked for GM) tell me that it's tough to implement properly on N/A cars and a typical runner+log manifold works better.
#22 |
Well it was stock on the corolla so it must be good enough
#23 |
play every day
Hey Monchyxb and YarisPR...
Just wanted to thank you guys for inspiring me to do what you did.
| Custom Short Ram Air Intake Problem | laxsaint99 | DIY / Maintenance / Service | 10 | 04-27-2011 01:28 AM |
| Custom Intake manifold/w 1zz tb / direct port nitrous | blacksandiegovitz | Items for Sale by private party | 28 | 11-23-2010 08:57 PM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| My Custom Intake | RacerFreakXXX | DIY / Maintenance / Service | 7 | 12-21-2008 07:32 PM |
