![]() Drives: hb Join Date: Apr 2011
Slide Key
does anyone has this ?
this video is for other male but is the key will look the same http://youtu.be/7CYQFOMwWIg i find it cool and kind of cheap. https://www.ikeyless.com/vehicles/To.../2010/1000690/ you can also find it on ebay $5 cheaper http://www.ebay.com/itm/NEW-UNIQUE-T...ht_2440wt_1185 |
Free Mustache Rides
not too bad
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
very cool but:
"Key Cutting/Programming Programming instructions are not included. This device requires cutting and programming by a dealership or locksmith"
i dont see a but...
that means that it is a blank key, you take your normal key and the new key to a locksmith to create a copy. programming is only in the case of inmobilizer transponders or in-key control remotes, mine doesnt have either... |
i didnt think any yaris came without the immobilizer
mine doesnt have inmobilizer (im outside USA).
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
I love those slide key things.If you have a car like a tC that has the transponder in the key you just have to take it out and transplant to the new key after it is cut for the lock.
Yaris has no imobilizer that I have seen,but if the wire on the drivers strut tower is loosened(it is the upper ground bolt..) the starter will start the car....lol.....or at least my car,no key needed....IDKY |
Free Mustache Rides
Just go for it. I may too if I find an all black one.
| Tags |
| key, slide |
| 2007 Yaris: looks like I only have a "valet" key. Options? | choppa | DIY / Maintenance / Service | 11 | 11-21-2016 10:23 AM |
| Transponder key programming | teddy | DIY / Maintenance / Service | 6 | 04-28-2015 06:32 PM |
| 2010 Yaris Sedan - Need Key Programmed to the Immobilizer | vst | General Yaris / Vitz Discussion | 0 | 04-17-2011 04:29 PM |
| Reemplazo Swichera | yukardo | Central and South America | 3 | 04-03-2011 12:11 AM |
| Need remote key | fraenx | DIY / Maintenance / Service | 1 | 06-26-2009 07:29 PM |
