![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
05 Echo changing time on clock
OK its not a Yaris but i thought maybe a former Echo owner remembers how to change the time on an 05 Echo. the radio unit is that odd one that came with no lights for the buttons,at night only the screen lights up.
Heres the radio, that button that says clock only changes the display from clock to channel. i;ve tried many combination's of holding 2 buttons at the same time and also holding the clock button itself for various time periods. havent found the trick yet..
Have Yaris will travel.. Last edited by jambo101; 11-09-2011 at 07:43 AM. |
OK then i guess its going to be an hour off till next spring..
Have Yaris will travel.. |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Maybe try this:
http://wiki.answers.com/Q/How_do_you...03_Toyota_Echo It would appear that your radio has an H above the number 1 and an M above the number 2. This could mean Hours and Minutes? Can't tell what the symbol above the number 3 is. On some USA cars (not Toyota), you change the time when the radio is off, so perhaps try the AM button with the car powered on but the radio off. Give it a try. What do you have to lose if it doesn't work?
Thanks Revsson ,that was the way to do it, hold down the clock button and adjust time with the H and M buttons..
| Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 07:40 AM |
| Toyota Echo and Yaris TWM Short Shifter Sale! | TWM Performance | TWM Performance | 3 | 08-24-2009 11:50 AM |
| long time lurker, first time poster | tekmoe | New YARIS Purchase Forum | 1 | 10-04-2006 01:43 AM |
