Old 11-29-2011, 11:41 PM   #19
dawin2122
dawin2122's Avatar
Drives: TOYOTA YARIS SEDAN S ROJO
Originally Posted by 400 dollar yaris View Post
are you using the stock head unit or did you change it?
IF THE QUESTION IS FOR ME NO THIS IS MY HEAD UNIT
dawin2122 is offline   Reply With Quote
Old 11-30-2011, 10:33 PM   #20
400 dollar yaris
400 dollar yaris's Avatar
Drives: 2007 Yaris sedan
when you removed the stock head unit did you happen to see any of the hook up ports needed for an amp/subs? also, im still stuck on what materials to use? i have plywood or i could go buy some mdf. question is.. is it worth buying particle board over plywood that i already have in the garage?
400 dollar yaris is offline   Reply With Quote
Old 11-30-2011, 11:04 PM   #21
dawin2122
dawin2122's Avatar
ok if you got plywood of 3/4 inches use this plywood is my recomendation sonds good for me and i post photos of my oem head unit
Old 11-30-2011, 11:27 PM   #22
TOLMACH
Drives: soarer
you gonna need the hi-low level signal converter if you plan to use the stock HU
Old 11-30-2011, 11:32 PM   #23
dawin2122
dawin2122's Avatar
yep something like that
http://www.ebay.com/itm/HIGH-LOW-CON...item3f101ee7e9
Old 12-01-2011, 03:12 PM   #24
400 dollar yaris
ok cool so what did you use to seal your box? liquid nails?
Old 12-01-2011, 03:33 PM   #25
TOLMACH
Drives: soarer
you can use pretty much everything that is available to you
Old 12-02-2011, 03:03 PM   #26
400 dollar yaris
so the more air tight the better the box. correct?
Old 12-02-2011, 03:56 PM   #27
TOLMACH
Drives: soarer
the box/cabinet should be rigid and strong.. and yes.. no major air leaks / airtight overall .. I normally leave a small hole somewhere .. (temperature / pressure inside and outside the box issue)
Old 12-02-2011, 08:04 PM   #28
dawin2122
dawin2122's Avatar
ok i use a very strong wood glue but liquid nails is good to and screws and then for the corners inside the box caulking i hope this helps
Old 12-03-2011, 01:42 PM   #29
400 dollar yaris
how big of a hole ? if its to big couldnt it mess up the speakers?
Old 12-03-2011, 01:44 PM   #30
TOLMACH
Drives: soarer
Sure it can.. just a nice small nice hole like 3 mm in diameter
Old 12-04-2011, 03:47 PM   #31
400 dollar yaris
and that should be small enough to not harm the speakers?
Old 12-11-2011, 07:08 PM   #32
400 dollar yaris
does the box have to have divided chambers inside the box? or can the two woofers just share the one compartment?
Old 12-11-2011, 08:10 PM   #33
dawin2122
dawin2122's Avatar
divided
Old 12-21-2011, 10:59 PM   #34
400 dollar yaris
ok so ive decided on this amp but i was wondering if the alternator can handle this much power anyone know the alternator ampage? or do you know if it will be able to power the amp. http://www.walmart.com/ip/BOSS-Audio...ifier/15780045
Two Twelve Inch Woofers with box for sale Daddie Y Items for Sale by private party 0 03-29-2010 03:00 PM
2 12 inch Speaker Woofers with Box babie y Items for Sale by private party 0 03-01-2010 09:54 PM
Sub Box Desgin talnlnky In Car Entertainment + Electronics (audio / video / alarm) 5 08-23-2009 01:45 AM
DIY: Custom Hidden Trunk Box (08 Yaris 3D) goku87 In Car Entertainment + Electronics (audio / video / alarm) 0 10-19-2008 05:43 PM
