Old 12-16-2011, 02:23 PM   #19
^ Agreed. It's very inconvenient to maintain the proper fuel ratio for your tune that way. However, the tuner may not intentionally be using a band-aid. He just may not be familiar with the advantages of WMI. I sure wish I knew about it 6 years ago. Tuning my tC was difficult.
Old 12-16-2011, 07:23 PM   #20
upgradedyaris
Drives: Yaris & Supra
For the 115 trap, I would suspect around 260 wheel judging by weight of car. 400 is way off for that trap whomever suggested that. It's different to see someone do mods to these cars to this extent.
I've been running WMI for a few years and over 700 WHP on my Supra. Best thing I've done. Car makes more power on Race etc...
Good job
Originally Posted by TURBO YARIS View Post
Your tuner is using a "bandaid" to solve any possible detonation issues. Is the pump gas i your country "leaded" or "unleaded"? Also what is the high octane you can buy @ the pump? Mixing race & pump is not the best thing to do.
Running WM is great and you can tune accordingly so essentially, lower octane won't really matter.
upgradedyaris is offline   Reply With Quote
Old 12-16-2011, 07:27 PM   #21
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Good job
That is correct, 260whp was what I was around 23psi dialing in for 12.50 index class. I wasn't trying to run my quickest ET, it just happened.
300 whp at 27psi ( never ran that on good track with slicks).
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 12-19-2011, 10:17 AM   #22
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by Blown_xa View Post
93 octane pump gas, with water methanol injection ( peak windshield washer fluid). 12.29 was my quickest ET, once tracks open again after the winter I will run full boost on that same track.
Im confused here..... are you using water or methanol mixture or else ?
This applies to garm aswell...
Parmas is offline   Reply With Quote
Old 12-19-2011, 12:31 PM   #23
50/50 distilled water + methanol
Old 12-19-2011, 01:46 PM   #24
A-Dingo-Ate-My-Baby
Drives: yaris
does anyone you've seen use peak windshield fluid for injection ?
or is that just a myth ?
COMPOSITION / INFORMATION ON INGREDIENTS
MATERIAL CAS# <35% BY WT
Methanol 67-56-1 200 ppm (260 Mg/M3)
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-19-2011, 06:54 PM   #25
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Yes, I use peak windshield washer fluid. The one rated at -20 degree, which is 35% methanol.
Ptuning.com
Old 12-19-2011, 07:23 PM   #26
^ I've seen that too.
I buy 5-gal methanol buckets and share with my friends.
Old 12-20-2011, 08:38 AM   #27
Parmas
Parmas's Avatar
Could you tell me the Brand name of this washer fluid?
Is it ready mixed with methanol?
Old 12-20-2011, 11:24 AM   #28
Yellow Heet (left) is 99% methanol. Great way to buy smaller amounts.
Old 12-27-2011, 03:52 AM   #29
Parmas
Parmas's Avatar
Curious how much it cost a bottle of yellow Heet ?
Old 12-27-2011, 02:05 PM   #30
^ Google is an excellent source to answer that question.
Old 12-27-2011, 04:02 PM   #31
Parmas
Parmas's Avatar
Is there any other way instead of using methanol ? ... I mean cheaper and not that rare to find
Old 12-27-2011, 07:53 PM   #32
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Peak -20. pick it up at grocery store, gas stations.
Ptuning.com
Old 12-27-2011, 10:51 PM   #33
This must be related to your location.
I get 5 gallons of methanol for about $40. That would last me well over a year if I didn't share it.
Considering what you have into your car (and that you aren't going to race every day), I don't see how that's expensive at all. It takes me a full race day on road course (not drag racing), to use most of a gallon. Drag racing hardly uses any at all.
The spray doesn't change volume, it either sprays or not. So 12 seconds of water/meth per pass is a VERY small amount for drag racing.
If you want me to try and sneak you some HEET through customs, email me. LOL
Old 12-28-2011, 12:54 AM   #34
Parmas
Parmas's Avatar
Here in Malta for $40 we get 20 litres unleaded pump fuel. I imagine 20 litres of methanol would cost $80 by least !
I will check out for more but I don't want to tell too much people that I am going methanol. I want it to be my secret weapon
Garm, I appreciate your hellp, so in case I decide to buy what is the total cost involved for at least 2 gallons?
