Old 12-19-2011, 08:32 AM   #379
Originally Posted by spectra View Post
to do this do I need to buy a new terminal pin for the ecm? where can I get this?
I have the ECM pins available.
Old 12-23-2011, 03:57 PM   #380
spectra
spectra's Avatar
Drives: 2007 Yaris
thanks so much! I got everything in and the test run went perfectly!
spectra is offline   Reply With Quote
Old 12-23-2011, 08:25 PM   #381
Nice! And, in plenty of time for your road trip.
Old 12-23-2011, 08:59 PM   #382
spectra
spectra's Avatar
Drives: 2007 Yaris
Yup! even had time to clean the car top to bottom
Old 12-31-2011, 10:04 PM   #383
the beagle
Drives: '08 Liftback
Cruise for Christmas!
After reading the entire thread on DIY cruise, I installed a $9.73 cruise on my son's 08 liftback, thanks to all of you for your perseverance and innovation. We ran the wires to the console between the seats. The two button controls are partially covered by the brake handle. A very clean install if I do say so myself.
CTScott, how can I get one of those ECM terminal pins?
the beagle is offline   Reply With Quote
Old 01-01-2012, 03:52 PM   #384
PMed with payment info. I have the pins available.
Old 01-07-2012, 12:15 PM   #385
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
I've used the CTScott cruise control system and procedure. works great. I have little experience working on cars. successful install.
33.7 mpg in PA
bad is offline   Reply With Quote
Old 01-07-2012, 12:20 PM   #386
bad
Winterizing
bad's Avatar
oh but i should mention you'll need a variety of butt splices and extra wire ... i wish i could remember the gauges but its all around 16 to 22. depening on what wire you use to ground you might need a different gauge lug for that too.
33.7 mpg in PA
Old 06-13-2012, 07:59 AM   #387
menz
Drives: yairs blue 2007 automatic 1.3
I am from Egypt (middle east). I have seen this DIY years ago but never had the guts to do it. I am a noob when it comes to car mechanics and also afraid of electronics :D. I don't know if my car has cruise function. To summarize, I need to check if PIN 40 has 12 volts when ignition on. Wish me luck everybody. I hope that the car has the function so I can do it, my 300 kms daily route to work would be so much better. I think that toyota must have installed it in all the cars not specific to a certain segment. When I first bought the car it had no rear speakers and when I bought the speakers and during installation, I found out that all the wiring is done and all I have to do it place the speakers and that was it. Do I need to remove the steering wheel to get to the D3 connector??? :d
menz is offline   Reply With Quote
Old 06-13-2012, 08:27 AM   #388
Unfortunately your Yaris does not support the OEM cruise control. For 06-11 Yaris, only US/Canada ones with the 1.5L engine have it built into the ECM.
Old 06-13-2012, 02:13 PM   #389
menz
I really wished I have it. So just for my own curiouisity which one is the D3 connector where is it exactly
Old 06-13-2012, 03:09 PM   #390
It is on the bottom of the steering column. My complete DIY shows how to get to it:
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 09-01-2012, 12:40 PM   #391
yaryarbing
Budget Buster
yaryarbing's Avatar
Drives: 2007 Polar White Sedan
It Works!
Just installed the two switch DIY cruise control on my '07 Yaris Sedan. Can't believe it works! Not that I had any doubts in the DIY instructions. I have zero experience in electronics. I just bought the parts (<$10!), installed as instructed, and I now have cruise control!
Thanks so much for this thread and instructions. I am a traveling salesman with a four state territory. The cruise will make my travels SO much easier
-Yaryarbing
yaryarbing is offline   Reply With Quote
Old 09-02-2012, 06:56 AM   #392
Originally Posted by chanka View Post
Hi Scott,
If I don't have cruise control in my 08 yaris (M5) (New Zealand New) hatch how can I fit CC ?
Cheers.
Chanka
For your car you would need a complete aftermarket system, since your ECM does not have the functionality built in.
Old 03-11-2013, 08:42 AM   #393
fascar228
Drives: vitz RS 1.5L 2006
Hi All,
I have a 2007 Vitz JDM 1.0L can the Cruise control mod work for my vehicle....
fascar228 is offline   Reply With Quote
Old 03-11-2013, 08:58 AM   #394
mf4361
Drives: Yaris Sedan
Since this thread is revived, I have to say, It worked on my 2007 Sedan (Canada)!! Started out with no tool, I spend ~$15 on it. Compare to, let say, OEM Cruise from dealership its almost nothing. Thanks CTScott for the awesome DIY writeup and everyone's help.
Now I need to work on making aesthetically look good.
mf4361 is offline   Reply With Quote
Old 03-27-2013, 09:31 PM   #395
johntam
j&t
Drives: 2007 4 door hatch back
Thanks guys for the detailed instructions for the cruise control installation for my '07 \yaris. It works awesome. J&T
johntam is offline   Reply With Quote
Old 06-21-2013, 03:33 AM   #396
bonox
Drives: Bronze 07
Hi All
I tried this today on my December 2006 YR. Is there a way to tell if you've made a connection to pin40 on A21? Is there a test resistance to ground or another pin for example?
Mine also does not have the blue wire populated in the fuse box for the clutch switch either. Does this mean it's a no go? There is a pin at the bottom (just not a wire coming out of the plug), which I tried grounding, but couldn't get CC to work.
Thoughts any of you gurus? :)
bonox is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
