Old 12-28-2006, 12:16 PM   #1
binspoonal
Drives: Black LB
Dash Kit for LB
Hi,
Where can I find a kit other than online, ebay, etc.. I'm looking for a store that has them. I've called Best Buy, Circuit City, local stereo installers and no one has them..
Thanks!
binspoonal is offline   Reply With Quote
Old 12-28-2006, 12:45 PM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I took mine out because I went to a double DIN setup. I think I have all the pieces.
I could sell you mine for like $15 shipped if you don't mind that it has been used for about a month.
PM me if you want it.
Old 12-28-2006, 09:55 PM   #3
sewid
Aussie Yaris Nut
Drives: AUSDM Yaris YRS
How did you fit a double din unit in the dash? I was under the impression that the space is 1.75 DIN high?
sewid is offline   Reply With Quote
Old 12-29-2006, 03:12 PM   #4
Violin
Violin's Avatar
Maybe yours is. The USDM Yaris is double DIN.
Old 12-30-2006, 04:16 PM   #5
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
i couldnt find any dash kits for my yaris sedan (it was radio delete, no stereo to start out with) so i made my own out of aluminum...wasnt too hard, just took a cutoff wheel and some time.
Old 12-30-2006, 10:31 PM   #6
eflb55
its EF LB 55
Drives: Toyota Yaris 2007 Sedan (US)
I actually had the integrated dash setup for my yaris and ended up buying the non integrated double din radio bezel for 90 dollars. I then bought a double din kit for a single din radio and then put one of those little compartments below it for the remote/crap I have laying around.
eflb55 is offline   Reply With Quote
Old 03-11-2007, 10:19 PM   #7
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
I havent put a double din in but from what I get you pull out the stock unit. Rape it of the bracket on the side. Bolt that to the new double din HU then bolt it back in. You will have a lil bit of gap on the sides but I think the top to bottom is spot on. Someone correct\verify me though.
jdubau55 is offline   Reply With Quote
Old 03-13-2007, 09:44 AM   #8
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
That's exactly right.
Reuse the stock bracket, which you have even if you have the radio delete cover. I found that the stock bracket had "bumps" on the inside so I used an angle grinder to sand them off. There will be gaps on both sides, but if you had the radio deleted, then you probably have a black plastic cover for the empty hole.
What I did was take the plastic cover, and cut the sides off with a hacksaw, then glued them on the inside of the radio surround panel. It isn't perfect, but it was free and no more gap.
Also, the stock bracket is much stronger than the plastic shit from Scosche. We had one of their kits in our Echo, and we were rear ended.(it was written off) The deck popped out on impact. Good thing I didn't have the screen out!
Last edited by earljail; 03-13-2007 at 09:47 AM. Reason: Added info about aftermarket brackets.
earljail is offline   Reply With Quote
Old 03-13-2007, 05:10 PM   #9
earljail
earljail's Avatar
Here- the first pic is how large the gaps will be. Yes, I know that the trim piece is upside down.
The second one is with the "hole-fillers" I custom made for $0.
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
Trim/Dash Kit (for single DIN headunit) for Yaris yet? bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 46 09-01-2006 07:30 AM
Dash Kit if interested....ebay fnkngrv Cosmetic Modifications (Exterior/Interior) 0 07-03-2006 10:18 AM
