![]() ![]() Drives: BMW 3 Series M Sport Join Date: Jan 2011
Centre air vent part number
Hi guys, does anyone know the centre air vent part numbers, I require the vents and the black part the vents sit in, all these parts sit behind the radio surround
Thanks |
DAT'S RIGHT I GOTz 2
55670-52010-C0 for black
55670-52010-B0 for gray
If you PM me your VIN, I can look it up in the European EPC. There are a couple of different color codes, so I would need to VIN to verify which your car uses.
The ones listed above would be correct for a Japanese built one, but not for a France built one.
or you can pull out yours and locate the part # on it
Thanks Scott will PM you in a mo
Can't get it off the original because it's half gone, it has two devices in the air vents half the vent was cut away Last edited by Nips; 01-16-2012 at 02:14 PM. |
Yours was built in Japan and the EPC is showing the gray (55670-52010-B0) as being the correct color code for your car. That part number contains the entire center vent assembly that snaps into the back of the radio surround.
Thanks Scott for your help, much appreciated
| Help with part number or name. | thorasaurus | DIY / Maintenance / Service | 2 | 09-29-2011 11:43 PM |
| driver rails part number help | joeharth | DIY / Maintenance / Service | 1 | 11-13-2009 01:44 PM |
| Part number for VIP Alarm | mehullica | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 10-27-2009 08:00 PM |
| Finish Sedan S Intake, Paint Caliber, Air Vent Lights | jamal1984 | Performance Modifications | 9 | 03-12-2007 11:57 AM |
