Old 01-17-2012, 04:33 PM   #19
BLH
Drives: 2007 Yaris Sedan
I am a very low mileage driver.
At around 13,000 miles my 2007 sedan had a water pump failure.
Pink spray from the front to the back of the inside hood.
BLH is offline   Reply With Quote
Old 01-17-2012, 06:25 PM   #20
brg88tx
Drives: 07 Yaris Sedan, Auto
i bought my 07 yaris sedan used with 58000 miles on it. i did notice some red splash under the hood above the water pump pully. since then i have watched my coolant level and i haven't lost any more. my car now has 74000 miles on it. i dunno
brg88tx is offline   Reply With Quote
Old 02-02-2012, 09:37 AM   #21
ajmarshall169
ajmarshall169's Avatar
Drives: 2007 toyota yaris sports
what type of sound does the water pump make when it is going bad. at first i thought it was my belt but now i believe it may be the water pump i havnt notice any leaks yet though
ajmarshall169 is offline   Reply With Quote
Old 02-04-2012, 08:36 AM   #22
10 Francis
Drives: 2010 Yaris S HB
Toyota has had some problems with their water pumps lately. the 2AZ engines, especially in Camrys and, to a lesser degree, RAV4s and others, are notorious for leaking at relatively low mileage. I had a 2-year-old Camry on my stall one time with 8,000 miles on it that needed a water pump. The 2ZR in the Corollas has also had a little trouble. If you replace that water pump, the factory water pump has a stamped-steel plate, but the new one appears to be cast aluminum. 1NZs have had fewer problems, but it's still not unheard-of.
Some people attribute this to the new Super-Long-Life coolant (the pink stuff), because they say it's thinner. I'm not convinced. I think that's just a perception, as the SLLC comes pre-diluted and the regular Long-Life (red) coolant does not.
Also, the water pump is covered under the 5-yr/60,000-mi powertrain warranty.
10 Francis is offline   Reply With Quote
Old 02-26-2012, 12:16 PM   #23
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
I'm sitting 80k miles and getting a nasty rattling noise under the hood. It sounds exactly like a video that c dub posted in another thread. I'm not getting any spray or leakage that I can tell though. Now I'm just wondering if this is something I can manage myself and where to get the pump?
wsladaritz is offline   Reply With Quote
Old 03-02-2012, 11:03 AM   #24
brg88tx
wondering if any improvement has been made to the oem yaris water pump. mine is grinding and needs replacement, i have 75,000 miles on it, so out of warranty. dealership quoted $450-$500 to replace it. i do not want to replace it with another faulty oem pump unless they have improved it somehow. thinking about buying a good aftermarket pump (around $45) and paying a mechanic $150-$200 to put it on.
any toyota service people have any info? thanks
Old 03-03-2012, 10:45 AM   #25
brg88tx
i've decided to have a local repair shop replace it. i bought a gmb water pump at advance auto parts for $40. the mechanic said he'll charge me $130 labor to install. $170 much better that $450+ from the stealership. I'm having it installed monday and will update.
Old 03-03-2012, 10:46 AM   #26
brg88tx
btw if anyone is wondering, this gmb water pump appears to be very well made. made in japan.
Old 03-04-2012, 06:01 PM   #27
mryaris
Drives: 2010 Carmine Red hatchback
I have had very good luck with GMB pumps over the years, so you shouldn't have any issues with it.
mryaris is offline   Reply With Quote
Old 03-05-2012, 08:23 PM   #28
brg88tx
just an update. gmb water installed today and i can't believe how quiet my car is again. the belt was dry and cracked so they replaced that too (only $9).
Old 03-06-2012, 02:43 PM   #29
Em_
Drives: 2007 Yaris
how much for the whole job ? $$$
Em_ is offline   Reply With Quote
Old 03-06-2012, 02:55 PM   #30
ajmarshall169
im at almost 100,000 miles and no problems, but whats this about a seat belt recall. i have a 2007 toyota yaris s. is it a big problem
Old 03-06-2012, 03:44 PM   #31
BLH
There is some sound deadening foam pieces around the seat belt retractors.
When the Air Bags go off a charge in the retractors locks the seat belts. Sometimes the foam would start burning.
I had mine done. They removed the foam for the recall.
http://www-odi.nhtsa.dot.gov/acms/cs...31&docType=RCL
Old 05-26-2012, 04:47 PM   #32
Chewy89
Drives: 1.5L '07 Yaris Liftback
My yaris is also having the exact same issue as yours right now, at about 80K miles, and no leakage that can be seen right now. I'm glad to know I'm not going crazy :3
Chewy89 is offline   Reply With Quote
Old 05-26-2012, 08:25 PM   #33
auxmike
auxmike's Avatar
I have a spare Delco water pump waiting on my bookshelf for when my first replacement goes....
Old 05-27-2012, 06:00 AM   #34
swidd
Drives: Yaris HB
Pump began to seep at a few hundred miles before 100,000, on my 2007 HB. Noticed the coolant would get low even after re-filling, then looked under the pump and it was pink.
Old 05-27-2012, 08:04 PM   #35
41magmag41
Drives: Loaded 2007 mica silver sedan
Ran my 2007 to 137000 and had no problem with my h20 pump. Only major problem was the rear wheel abs sensors went. If I didn't have the extended warranty it would have cost me over 1500 for the replacement sensors. Had an accident in december and totaled the car. My only concern is that I hit a guard rail at about 45 mph after sliding on black ice and the air bags never deployed. That bothered me. I now drive an moderaterly priced suv and only miss the gas mileage the yaris afforded me.
41magmag41 is offline   Reply With Quote
electric water pump help! mandriu Performance Modifications 39 10-24-2009 02:56 AM
bye bye water pump cali yaris Performance Modifications 29 01-03-2009 05:06 PM
