Old 01-21-2012, 04:00 PM   #1
Dc1011
Drives: 08 yaris HB blue AT
Problem in Yaris found
Hey all.
So the dealer took a look at the car and figured out that one of the spark plugs was severely corroded and was causing a miss in cylinder 2
He said that because the car sat for almost a month after the wreck without being driven the spark plugs corroded over a little.
It's probably time for new ones anyway; 90,000 on the odometer.
Have many of you guys on here just changed the plugs yourself?
Dc1011 is offline   Reply With Quote
Old 01-21-2012, 04:23 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
They're pretty simply. All you need is a special deep socket to get the plugs out. if oyu try to do it yourself make sure you put some anti-seize compound on the threads of the plugs. ALSO MAKE SURE YOU DO NOT CROSS THREAD THEM. You do NOT want to have to get the head re-threaded.
Old 01-21-2012, 04:28 PM   #3
bronsin
bronsin's Avatar
Since they need changing every 100k miles its probably a one in the cars life deal for most vehicles.
At the rate I am going it will be ten years before I need to change them!
Old 01-22-2012, 12:27 PM   #4
mr_miles
Drives: 2013 Yaris
I check them every time I change the oil :) When they look to dirty or have too much corrosion that cant be cleaned, i change em'
When i still drove my rx7 I would change the plugs once every few months. I had a couple sets and i would pull them, clean them, and reuse them.
..........but thats a dirty old rotary that would foul a plug for no reason so I had to clean em'. lol
Old 01-22-2012, 12:36 PM   #5
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Originally Posted by Betrivent View Post
..ALSO MAKE SURE YOU DO NOT CROSS THREAD THEM.
If you happen to strip one....
http://www.google.com/search?q=helic...w=1138&bih=564
-Type 07 FFL-
My odometer 03/11
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Found a 2010 yaris with a stability control off button mr9865 New YARIS Purchase Forum 5 10-26-2009 03:43 PM
