Old 01-23-2012, 12:15 PM   #955
Jason@SportsCar
Originally Posted by racerb View Post
Sorry for continueing the hijack, but couldn't find any pictures of my steering column set-up. So here is a very simular set-up to mine on an MG, same basic deal hung verticle where mine hangs horizontal.
http://www.google.com/imgres?imgurl=...9QEwAw&dur=180
racerb
Similar to mine as well. Splined shaft with a quick release welded on. Simple, much lighter than stock, and further reduced the steering effort.
Old 01-23-2012, 12:29 PM   #956
I heard good things happened this weekend...
Old 01-30-2012, 12:06 PM   #957
Jason@SportsCar
Progress... Loynings head with Jun cams mated to the block. If I did not like my neighbors I would fire it up and do the break-in tonight. It will just have to sit till the weekend.
Old 01-30-2012, 12:26 PM   #958
33OH
Drives: '08 Yaris
We're not worthy.
Old 02-02-2012, 02:02 AM   #959
Jason@SportsCar
Just got the car back together. Tomorrow we make noise.
Old 02-02-2012, 02:50 PM   #960
Jason@SportsCar
It's alive. Now to schedule some dyno time.
Old 02-02-2012, 03:07 PM   #961
does it feel more powerful?
Old 02-02-2012, 03:17 PM   #962
Jason@SportsCar
My butt dyno could not tell as I sat in the car with the engine revving between 2000-3000 for half an hour breaking in the cams.
We cant exactly drive this on the street. The dyno will show the difference, as will laps at Willow Springs during the next race.
Old 02-03-2012, 02:24 PM   #963
Jason@SportsCar
On the dyno next Tuesday.
Old 02-03-2012, 02:37 PM   #964
Excellent. Finally. Thank you.
Old 02-03-2012, 09:04 PM   #965
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Sorry, could you run by what else is done to this motor also along with the jun cams? Just as a reference.
-Derrick-
Old 02-06-2012, 11:54 AM   #966
Jason@SportsCar
The Production class rules are fairly restrictive to the newer cars like ours, but we can still open it up a little: intake/exhaust ports opened up to match intake/header to a depth of 1". Multi angle valve job. Head decked to get us closer to our 11-1 max compression ratio.
Old 02-06-2012, 12:14 PM   #967
how much did you have to take off the head?
Old 02-06-2012, 01:26 PM   #968
Jason@SportsCar
I have not seen the build sheet/bill yet. Without being able to CC everything (I did not send the bottom end so they could not measure the piston volume) I am sure they went conservative. I know the pistons don't slap the valves, happy about that.
Old 02-06-2012, 02:10 PM   #969
lol
Old 02-08-2012, 12:37 PM   #970
Jason@SportsCar
The results are in, the Jun cams are an improvement over the custom grind we had done for the 2010 season, but they are not magic.
With the combination of head work and cams we picked up 12hp when compared to the stock engine we ran in 2011. However, just like with the custom grind cams we lost Tq below 5000rpm when compared to the stock engine - fortunately in this case we only lost 3ft-lbs, where the 2010 cams lost around 18ft-lbs.
While I was not jumping for joy at the final numbers, I was happy to see the top end power match our 2010 numbers, while regaining most of our lost Tq. Additionally, the power band with the Jun cams is much broader than the custom grind was, we have nearly 1000 more usable RPMs than we did before. From 5500rpm on we have more HP and Tq than either of the previous setups offered, and the power delivery is smooth.
If you are thinking about the Jun 9.5 cams keep in mind these are not a direct bolt-in. Your head will need relief cuts to clear the lobes, and without engine management you will not see the full gains.
Overall I give them a thumbs up, but expect to spend about $2k between the cams and head work.
Old 02-08-2012, 02:17 PM   #971
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
So this--combined with reverting the final drive--should make you much more competitive than last season? How's the gearbox coming along?
Old 02-08-2012, 02:18 PM   #972
ilikerice
ilikerice's Avatar
On behalf of everyone at yarisworld, thank you. lol
-Derrick-
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
