Old 06-10-2011, 08:58 PM   #73
enviri
enviri's Avatar
Drives: 2010 Yaris
or do you want a 3RZ (Tacoma 4cyl) inside a yaris?
Old 06-10-2011, 09:03 PM   #74
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
absolutly not.. way too much fab work for my skills.. ill leave that to the skilled professionals. lol
Old 06-12-2011, 04:09 PM   #75
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
Why the hell would they convert it to rear wheel drive.... :(
Rob Cohen called, he needs his altezza's for the next Fast And The Furious
yarislady is offline   Reply With Quote
Old 08-10-2011, 08:34 PM   #76
jpn6438
Drives: sleeper
Originally Posted by RXvedub View Post
My first post. I have an Echo with a celica 1zzfe TRD supercharged and a 6spd. AEM FIC 91oct
I dont know if its interesting anymore or not
By any chance that you can post up any write up that you have on the 1zz swap? Trying to get as much info that I can so that I can get a quote to get this done on my xA. So far I have a budget of $7k.
jpn6438 is offline   Reply With Quote
Old 08-11-2011, 03:22 AM   #77
w7ist
Drives: 08 yaris lb
Because then it would be a proper car. ;)
The yaris would have a much bigger following if it had a proper set up like that.
Unfortunately its an ass dragger.
w7ist is offline   Reply With Quote
Old 08-11-2011, 05:57 AM   #78
ilikerice
ilikerice's Avatar
ehh, i agree and disagree with that one. look at the mini cooper S.. fwd, handles like a dream for only 180hp.
at autocross, side by side with a mini cooper.. I was taken back how close the wheel base looked. Yaris is just disigned to be eco friendly, not a corner hugger
Old 08-14-2011, 03:54 AM   #79
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
Will someone please do a motor swap soon?
I'm waiting to die, and I can't do it until someone completes a Yaris motor swap. Please help me out on this.
you can be the first Garm
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 08-14-2011, 05:59 PM   #80
^ You mean "we", right?
Old 08-14-2011, 08:49 PM   #81
scioncrew
scioncrew's Avatar
Drives: SCION tC
lol i guess your wright WE can be the first.
Old 10-02-2011, 03:21 PM   #82
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Originally Posted by enviri View Post
btw here's a link for a 3S-GTE converted xD, im pretty sure since the XD and yaris share chassis, the install should be very similar. you can pm that guy for more info.
http://www.scionlife.com/forums/showthread.php?t=202097
Seen it in person,crawled under it and looked and honestly it fit very well,welding skills of course are needed to mount it....was a cool ride.
Old 11-05-2011, 03:15 AM   #83
ArmyYaris
Drives: Blazin' Blue 2007 Yaris LB
would a 1zzfe fit in an 07 yaris? looking at a swap to do when i get back from deployment
ArmyYaris is offline   Reply With Quote
Old 12-13-2011, 07:24 PM   #84
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
i want this in a yaris
161bhp v4 based off the ls series
http://www.motusmotorcycles.com/kmv4.html
ttr125fan09 is offline   Reply With Quote
Old 12-13-2011, 08:11 PM   #85
Jedz123
Two Wheeled Fiend
Drives: 08 Yaris 2D Lftback 5-speed
I recognize that! That's a motorcycle engine design. Cycle World did an article on it. Called the Motus MST-R
http://www.cycleworld.com/2011/07/22...pe-first-ride/
161 hp isn't anything too crazy for a motorcycle engine. from what i have heard that engine is a bit problematic hence why it hasn't gone into production yet.
The 1157cc motor that powers my Bandit 1200S dyno'd at my last dyno tune a respectable 134 hp to the wheel and 97ft/lbs of torque... That's wheel not crank ponies....Yes my bike is worked a bit but the bottom end is stock and the motor is the same cast as the one's that powered the frist GSX-R 1100s.
Now the Suzuki GSXR-1300R (AKA Hayabusa) 1340cc bumping out 178hp... Now that's a motor to drool about...
But I always hear motorcycle engines don't make the best swaps...
2008 Suzuki B-King
2001 Yamaha FZ1 (2005 motor swap)
1998 Suzuki Bandit 1200S
1983 Suzuki GR650
2008 Toyota Yaris 2DR HB (The Cage)
Jedz123 is offline   Reply With Quote
Old 01-24-2012, 11:24 AM   #86
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've done some parts research on toyodiy for the euro T-sport 2ZR-FE. The motor/trans side of the mounts are identical to the xD, but the body side are unique part numbers to the TS. The shifter cable is also a unique part number, assuming that you get the TS 6-speed EC6X transmission. That thing is completely different from the C5X series. If someone has access to a UK parts dealer, this could be a very easy swap.
Old 01-24-2012, 12:39 PM   #87
ilikerice
ilikerice's Avatar
this is very interesting to me also.. been pondering this swap for some time now. I have been going to the junk yards waiting for an xD to be totaled so I can get a look and take some measurements.
would the C5X bolt to the yaris 1nz and also the splines off the crank fit in the stock yaris tranny?
-Derrick-
Old 01-24-2012, 01:21 PM   #88
CrankyOldMan
The xD C50 uses the "same" bell housing and gearbox case as the Yaris. I say "same" because there are 2 different part numbers for the Yaris, depending on year of manufacture. The newer Yaris gearbox part number matches that of the xD, as does the bell housing.
I can't say with any certainty about the splines, but there seems to be a lot of possibilities of them being the same on the Yaris, Corolla, Matrix, Celica, etc. Looking up flywheel application charts for aftermarket items could help verify this. Even if there's a mismatch, the crank splines go into the flywheel, and the trans splines go into the clutch disc, so as long as the diameter and clearances are correct, it's not an issue.
Old 01-24-2012, 03:18 PM   #89
ilikerice
ilikerice's Avatar
this is becoming more and more likely then I expected.. I just want more displacement for the torque.. would like to turbo the 2zr afterwards.
thanks for the research your doing.. please keep us (may just be me) posted on things you find.
-Derrick-
Old 01-25-2012, 01:11 PM   #90
if the 2zrfe bolts to the yaris transmission, it should make for an easier swap.
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 05:01 AM
