#1729 |
Roadrunner Jr.
^For me they went in front of the turn on leads for my amplifiers. Mine were Bosch types though. I won't need them when the new processor comes along...
Derick, can you say, almost finished with the door panel trim rings? :) I'm rabbeting in the rings to fit down into the openings I made yesterday. They'll also be painted to the color of the car and fit with hand made grills. This will allow me to light up the speaker in the door with LEDs for a sweet effect when needed.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#1730 | |
Sq are them huge amps asking for 4 gauge power / grounds ? How are the terminals ? the new style where you don't need spades or do you have to crimp spades on there ?
#1731 |
Roadrunner Jr.
^Those amps are huge. They're set up like old A/B class amplifiers. Think ZR1000 meets Arc SE2300. The thing is that these are absolutely only running at 4 Ohm loads. Having run them last year to a Western Canadian regional victory in my class, through that whole time, they only became warm. Never were they over taxed or "railed". I'm not worried about 4 gauge wiring honestly. It works well given my situation.
![]() ![]() I've made the trim rings for the door panels. I've secured grill material as well. Now, it's about snugging the trim ring onto the door panel and then shaping some grill material over a blank...then it's primer and paint for the ring. ![]()
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 01-31-2012 at 12:58 AM. |
#1732 |
That's how my Brutus is set up , has the wiring going directly in the connectors, I love it ! Except i'm running my subs at 2 ohms out the box then it drops it to 1 at the amp, since it acts as a Mono. I'm seriously thinking about buying a few feet of the 4 gauge Knu Konceptz brand to run from my distro block to my amp, right now it's some cheap o 4 gauge but it's more like 6 gauge.
What size speaker wire do you have to run up to the front components and later on your subs ? And how many watts RMS are you running them amps @ 4 ohms ?. Almost forgot ...Are you going to run any type of fans on them amps or is the top being open going to be enough to vent them ? I plan on putting some Plexi glass over my amps with some lights and " show" type stuff, but i also thought about getting some fans to put on my sub amp since it's not going to be as " open " as now.
#1733 |
Yo Derick what did you ever do with them 6.5 Hifonics ?
#1734 |
They are back in their box, clean like new. I can't believe how good they are.
Well can't compete against the HAT L6s but still even with a LED light inside the ZEUS Hifonics can play low and fast. Was it you who wanted them right? D.
. CLA 250, 4MATIC |
#1735 |
Sqcomp, the cover for your L6SE's is looking great, I'm still debating how to do mine.
send more pictures... did you end up cutting the panel in that shape? My L6's baffle hit the panel on one side! was thinking on cutting more like you did, did you have the same issue? D.
. CLA 250, 4MATIC |
#1736 |
How much you asking for them ? Actually for the 6.5's and the Crossovers if you're not using them. I cracked one of the covers on mine.
#1737 |
Roadrunner Jr.
I'm running 12 gauge street wires to all my speakers. The reason? To support the lines my shop sells. No more than that.
The S2b amps are a true 450 x 2 which is great for headroom and dynamic transients. The S4b is rated At 120 x 2 and 240 x 2. This kicks up the tweeters and mid range speakers and gives good headroom as well. I'm not using the amp's onboard crossover which is really nice. Eventually I'll be moving to a new "brand" of amplifier in a few years. It's being designed right now and has to go through the entire manufacturing process. Think Genesis dual mono extreme WITHOUT the crossovers or anything that will change the signal aside from amplification. We're going for a true, unfettered amplifier. We may also be thinking about class A as well. There's so much more to say... And D, I'll be putting up more pictures of the panel. No worries.
#1738 |
Sq how do you have your gains set on the amp ? Here's a few questions :
Voltage of your rear outputs on your Deck (I think they're 5 V ) RMS of your Legatia's RMS of any other speakers/subs I guess what i'm asking is do you have your amp set to the voltage your stereo puts out. Maybe it's the old school way of doing it but please help me better understand. If you're deck puts out 5V's is that the max you want your amp (Level on the amp below ) ? Or is it all done by ear ?
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 Last edited by _S7V7N_; 02-01-2012 at 07:58 PM. |
#1739 |
Roadrunner Jr.
I'm setup a little differently than the average system. My head unit puts out an unclipped signal of 4.99 Volts at maximum output on the volume pot. I keep my volume pot at maximum output (62 on the deck's readout). That gives me as much fire going down the lines as possible. The signal then goes to my Bit One (soon to be PS8). The processor then takes it and has a field day. The signal voltage then gets sent to the amplifiers. Both the processor and the amplifiers have clipping indicators (on the GUI and side of the amp respectively).
I take a 1 kHz tone at 0dB and blast it though the chain (no speakers on the amps). It take an o-scope and read at each point, all the source outs, processor ins, and the amplifier ins for a smooth sine wave. From the sine wave reading kn the scope I move up on the amp gains since I start with the gains all the way down. I go until I see clipping and then back it down until I see a smooth wave. Why the test tone? It's a mean tone at the highest output level I can get off the information on a CD. That means I play it safe and never have any clipping no matter how loud. Therefore, I don't need to spend the time and money with constructing tweeter protection or launching speakers into outer space. It works for me. :)
#1740 | |
Stop right there, I'm lost! Honestly my knowledge doesn't goes that far, sounds very cool in white and black, and I bet it will sound much better behind the steering wheel. I hope some day I get to travel a-x the country and have a chance to learn all that! I will appreciate if you post more pictures of the grills for your LOWS in the doors. I just can't come up with an easy/nice solution. D.
. CLA 250, 4MATIC |
#1741 | |
D.
. CLA 250, 4MATIC |
#1742 |
![]() Drives: 09 Yaris Sedan Flint Mica Join Date: May 2009
This Thread is a "whole nother LEVEL" love all the post u guys have some crazy audio
i just have my lil pdx-5 but im happy for now
Big 3 Upgrade, Alpine CDA-105, Alpine Imprint, PDX-5, JL W3 Sub, UltraStart 4296M
#1743 |
Roadrunner Jr.
^I must apologize to Derick. I'm sort of piggybacking my experience in the Yaris with his thread.
I found that If I had my own thread I received too much naysaying. "Too expensive" this and "Your doing things wrong" that... as for this thread being a "whole nother level", I say take what Derick and I are doing, ask LOTS of questions and go and do likewise (as in your own little projects). @ Derick - I've actually got the trim ring blending onto the panel right now. It's down in the garage curing with a space heater close to it. Tomorrow night I'll finish up the rough blend. On Saturday I'll remove the piece, trim it down and then prep it for paint. Once it's painted I'll permanently attach it to the panel. Don't worry, I'll give you full pics and explain the process. Until I'm done, here's a teaser:
#1744 | |
D.
. CLA 250, 4MATIC |
#1745 | |
D.
. CLA 250, 4MATIC |
#1746 |
yeah nice rides, i noticed that there was one in Oakham! my sister lives there small world. Ya i had posted we should meet in the NE thread. see what happens
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
