Old 02-08-2012, 09:10 PM   #1
Billiam
Drives: '10 White Yaris 4D LB
Sedan wiper switch
I know there's lots of info on swapping the Liftback's wiper switch for one from the Matrix or Prius to gain variable intermittent wipers. However, the best that I can tell, there's been nothing on an OEM option for the sedan. Well, there is now. After doing some poking around I have found an OE wiper switch for the Tundra/Tacoma that works perfectly in the Yaris sedan. This is a plug-and-play deal.
Part # 84652-04141
If you want to enjoy your car, stay off of the internet.
Old 02-09-2012, 05:17 AM   #2
deathwisher
Drives: 2007 Yaris Sedan
Oh damn. now i wan one.. drool
deathwisher is offline   Reply With Quote
Old 02-09-2012, 07:54 AM   #3
CB900F2
Drives: 08 Sedan
Biliam... Is the length the same as the yaris one?... Do you mind sharing how much you paid for it??
thanks Biliam
CB900F2 is offline   Reply With Quote
Old 02-09-2012, 08:17 PM   #4
Billiam
thanks Biliam
Yes, it's about the same length...just a tiny bit longer to allow for the adjusting ring for the variable int part.
I think retail is about $150. I paid $115.
Old 02-10-2012, 08:11 AM   #5
CB900F2
Drives: 08 Sedan
Where you able to install the unit with out removing the steering wheel?
Old 02-10-2012, 06:59 PM   #6
Billiam
The steering wheel does not have to be removed for this install. You'll remove 3 screws...one under the steering column and one on each side, behind the wheel (you'll have to turn the wheel to access these) to separate and remove the steering column cover. You then disconnect the 2 connections on the bottom of the switch, push in the tab that holds the switch in place and pull it out. Reverse the order to install the new switch.
Old 02-14-2012, 12:39 AM   #7
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Where is the option for "Like"
D.
CLA 250, 4MATIC
Old 04-15-2023, 08:05 PM   #8
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
Can confirm that part number works in my 2007 sedan. Got an aftermarket switch off ebay for a fraction of the price of the OEM unit (~$50USD). Functions and looks identical to OEM, but the "click detent" might not be as nice when physically moving it. Relay is also a bit more audible, but not enough to drive me bonkers or anything. Time will tell how it holds up. Thanks for sharing!
I followed CTScott's install guide and it was very straight forward:
https://www.yarisworld.com/forums/sh...ad.php?t=15512
Kasbien is offline   Reply With Quote
Yaris Sedan Discontinued? green-phoenix General Yaris / Vitz Discussion 65 09-18-2010 01:52 AM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 03:11 PM
