![]() Drives: toyota yaris Join Date: Mar 2012
unable to start the car
i owned a 06 Yaris - bought the car more than 1 year ago, and seemed to encounter this problem where i am not able to start the car if i do not use a for a few days.
Is this a known issue? Any resolutions? |
Is the battery dead and you have to charge or jump it to start or is the problem something else?
battery not dead - the first time when i encountered this, the bat was only 6 months old.... the mechanic has no clue too... i am wondering if the rest of the yaris owners have encountered this problem
and yes, it becomes alive when i jump start the car/battery...
What does the mechanic do to get it started, or is this the first time it happened?
Does the engine turn over with the starter, or exactly what happens/doesn't happen when you turn the key?
In that case, it is a dead battery. The battery is too weak to start the car. If it only does it after parking the car for multiple days, then it could be that you have something installed in the car that is drawing significant power when the car is not running.
Normally with a good battery, you should be able to go 2-3 weeks without starting it and not need to jump it.
i did not install anything that is drwaing significant power from the car... geez... wheni try and start the car, it's has this continuous ticking sound... dunno how to describe to you
when i stick the key into the ignition, it does not turn fully - probably like the first gauge with the ticking sound... usually it will turn all the way and the car will start!
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
That click-click-click sound the starter is making is because the battery is LOW on voltage. The jump start brings the voltage back up, and the car can start. As CTScott said, you probably have something drawing power when the car sits, and/or your alternator isn't charging the battery fully, and/or your battery is bad.
-Get the battery tested. -Get the alternator tested. -Have the mechanic check the draw on the battery when the car is sitting with the key off, which will tell you if you have something drawing power, like a bad stereo or a dome light on. Don't assume you have nothing wrong with the wiring. If you are the second owner, you don't know what the previous owner did. |
| KCALB SIRAY - Photo Scavenger Hunt | KCALB SIRAY | Photo-Video-Media Gallery | 5 | 03-02-2009 10:44 AM |
| LEGATO`` - Photo-Scavenger Hunt | LEGATO`` | Photo-Video-Media Gallery | 1 | 03-02-2009 10:38 AM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
