Old 03-27-2012, 02:01 PM   #19
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
Kinda reminds me of a 'hot soak' issue in first-gen vibe/matrix. when the car has been driven for a while, then stopped attempting to restart in 20 or so minutes results in a prolonged crank and no start. Doing it again immediately starts it ok. Toyota issued a software 'fix', but it only made it better without eliminating the issue completely.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 05-26-2012, 08:51 PM   #20
othater
Drives: 07SedanS06Taco
I'm glad I found this thread. I was about to buy another starter.
87K miles and never happened until recently.
This is the same symptoms my 4Runner had when the starter contacts were worn and the plunger was sticking which I replaced the contacts and have been working fine for the last three years.
I was searching for replacement contacts for a Yaris starter and did not receive any references for vendors. Just complete starters.
othater is offline   Reply With Quote
Old 05-27-2012, 12:03 AM   #21
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Just an update, since I did the 1ZZ throttle body swap I have not had this issue...at the rate I was experiencing it it should have happened by now.
-Type 07 FFL-
My odometer 03/11
Old 07-08-2017, 07:18 AM   #22
Antonius
Drives: Toyota Yaris 1.3 Spirit
Same odd infrequent problem
Hi. I have a Yaris 1.3 Spirit and it does the same thing, intermittently though. About every 50 starts. If it was normal I guess it would have done it from the start, however it only started once the car was about 10 years old. It has 140,000 km or ±90,000miles on. I guess I will replace the whole started motor and relay/solinoid thingy.
Antonius is offline   Reply With Quote
Old 07-22-2017, 12:27 PM   #23
bambam28
Drives: Yaris Hatchback 2012 SE
Same problem here, mine starts, but the starter sticks lile 1 or 2 seconds after it already started. It only happens when starting the car in the morning
bambam28 is offline   Reply With Quote
remote starter, instaled but cant get tach sig? karl53913 DIY / Maintenance / Service 8 11-26-2008 10:40 AM
Remote Car Starter KittenRD Fuel Economy Forum 6 11-08-2008 11:53 AM
Starter problem wormley DIY / Maintenance / Service 2 10-29-2008 09:56 AM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
Starter dragging YarisTom73 DIY / Maintenance / Service 5 08-27-2007 12:11 PM
