can we install a button for ((P)) parking brakes
i wish to have a button in my yaris for parking brakes, instead of that handle, because i intalled an armrest recently which makes releasing the handle a little difficult.. i know this will require some modifications and special equipements. anybody taught about it already !!
That would be a little tricky to do. Besides needing a fairly powerful solenoid to yank the cable, you would lose the ability to apply them gently (as you would need to do if you were using them in an emergency situation where the hydraulic brakes failed).
2ZR swap. DO IT! Ask how!
The big problem I see is that you would need something like the air brakes on a large truck. They are set up so that they are "on" when they are not pressurized, and "off" when they are pressurized. You would have to add an air compressor and a pneumatic cylinder that is strong enough to pull on the parking brake cable, in addition to the button and wiring. It could be done, but would be pretty expensive, and complicated.
The scary part of that is if it fails while you are driving, it will be the same as making an "e-brake" stop. If you have a manual transmission, just park with it in gear instead of using the handbrake. I don't use my handbrake at all because it can freeze stuck in the winter. |
#4 | |
yarismo: Here's a link to what I'm talking about: http://auto.howstuffworks.com/auto-p.../air-brake.htm |
#5 | |
#6 | |
I'm still pretty green with my engineering skill set, so it's good to hear an alternative solution from another engineer. |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| ))) Tein Super Compact coilover install tips ((( | aucorium | DIY / Maintenance / Service | 4 | 10-25-2011 12:42 AM |
| max air conditioning button | Idahotom | General Yaris / Vitz Discussion | 0 | 07-06-2011 09:41 PM |
| HELP needed for carputer project: Powered USB hub install | Astroman | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 11-01-2010 05:18 PM |
