![]() Drives: 09 Yaris Join Date: May 2011
Dash light (!)
So this light is on. Seems to be the tires. Put air in one tire and the light went off but the next day the light is back on and tire is ok. I am getting oil change and tire rotation next month, could it be rotation time or something?
TIA Connie |
Not its not rotation time if the yellow tire icon light is on. The car is trying to tell you air pressure in one of the tires is low.
Maybe its another tire? Check them again. If the pressure is good (32 psi -35 psi) you have a car that means well but should shut up. Tell us what happens!
thanks, I will check them this afternoon. I will keep you posted.
Yep 10lbs low same tire... off to look at tires. Thanks!
How many miles on the tires?
I think its possible you pickedup up a nail or something. Which can be repaired (plugged) if the tire is not too old.
| F/S Dash Light Dimmer Switch | 1NZYaris1 | Items for Sale by private party | 4 | 09-26-2012 03:55 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Intermittent low oil pressure light. | Inspector14 | DIY / Maintenance / Service | 23 | 03-29-2010 01:46 PM |
