Old 04-03-2012, 03:04 PM   #19
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I've changed plugs twice already (100,000km between changes) and they looked nothing like that. They were a bit brown, but electrodes still looked fine. I could have left them in but I changed them any way.
I use Iridium just because that's what was there originally and it hasn't let me down.
Also I've already done what DMZ has suggested and put anti-seize on the threads.
devinlamothe is offline   Reply With Quote
Old 04-09-2012, 11:43 PM   #20
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
The hotter they get, the faster they burn. Same as those "ultrabright" headlight bulbs. Trust me, you do NOT want to change those on a frequent basis!!!!
Old 04-10-2012, 01:09 AM   #21
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Anybody care to have me post up my Iridiums I pulled?
Old 04-10-2012, 01:13 AM   #22
firemachine69
Give'er.
If I weren't essentially driving my car (which is practically the dealer's now), I'd pull mine and check, too.
Old 04-12-2012, 07:16 PM   #23
Happy Little Pony
Drives: 2007 Yaris HB
I just replaced my Yaris' plugs even though I was "only" at 44,000 miles. They looked fine. The gap was still well within specifications. I won't replace mine that early again.
I don't know what an anecdote about the plugs people are using in their motorcycles have to do with what Toyota recommends for the completely unrelated Yaris. It's an apples vs. oranges argument.
Happy Little Pony is offline   Reply With Quote
Old 04-12-2012, 07:46 PM   #24
bronsin
bronsin's Avatar
An engine is an engine.
Old 04-12-2012, 11:18 PM   #25
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
you can't be serious........................................... ...........
Colin Chapman disciple
Old 04-13-2012, 01:39 AM   #26
fnkngrv
fnkngrv's Avatar
really when you look at the investment to replace plugs why is it a big deal to change them at 40-50k anyway if you want to? It cost me I think around 10 bucks.
Old 04-17-2012, 09:50 AM   #27
curtmaxwall
Drives: Toyota Yaris Spirit
Post
Here are sparkplugs out of identical four cylinder engines. The ones on the left are iridiums with 30k on them the ones on the right conventional plugs with 70k.
Note the slender electrode of one of the irids is totally worn away. The other three were normal.
Both owners reported normal operation and gas mileage.
Are Iridium plugs another thing to waste your money on like synthetic oil?
You decide.
Iridium is one of the hardest, strongest and rarely available materials on the earth’s crust. Iridium is the best, but too hard to handle. Iridium is 6 times harder, 8 times stronger and can withstand temperatures exceeding 2454° C. It improves firing performance, smoother idling, improved engine performance and when accidental fire and misfiring rarely occurs under various driving conditions so we can say it decrease fuel consumption. So I can say its better, if you like.
curtmaxwall is offline   Reply With Quote
Old 04-17-2012, 11:10 AM   #28
bronsin
bronsin's Avatar
Did you see the picture? The center electrode is trashed after only 30k miles.
How that happen?
Note the conventional plugs on the right. They are worn but the owner reported normal engine operation after 70k miles.
Old 04-17-2012, 11:34 AM   #29
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
This is an intersting topic on spark plugs in motorcycles. But those are sparkplugs out of a motorcycle. Different driving habbits. I find this topic more for motorcycles then comparing to a DD car.
Also, You cant judge all Spark plugs on 4 you pulled out of 2 vehicles. give me 100 plugs pulled out of 50 motorcycles and then come back. Even if that Iridium plug was that bad, It still fired and worked fine apparently with normal gas milage and running condition. SOO, maybe the Iridium is worn, but not completely, and it is still firing like a champ.
-Derrick-
Old 04-17-2012, 11:46 AM   #30
why?
why?'s Avatar
Drives: Yaris LB
especially considering the revs a typical modern motorcycle puts out.
Old 04-17-2012, 12:28 PM   #31
SAV912
Pirate Yaaaaris
SAV912's Avatar
So the OP has walked in with another rant about his vast knowledge of engineering, this time comparing iridium spark plugs from one motorcycle to conventional spark plugs from a different motorcycle, then lambasts those who use iridium spark plugs in their Yarii.
WTF.
Let's completely ignore the characteristics of a motorcycle engine that revs to 8500 when a Yaris tach doesn't even READ to that speed. Good info to relay, absolutely awful comparison and delivery. The Yaris never needed to be brought into this conversation.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 04-17-2012, 12:38 PM   #32
bronsin
bronsin's Avatar
All you got to do is explain where the end of the sparkplug went to.
Unlike you I allow others to make their own mind up.
Old 04-17-2012, 02:14 PM   #33
ilikerice
ilikerice's Avatar
out the exhaust is my guess..
I can't wait to read about the next tread installment of Prestone Yellow coolant VS. Toyota Red coolant.
-Derrick-
Spark Plugs platinum vs iridium Hard_Yaris Fuel Economy Forum 21 04-11-2010 09:37 PM
Where can I get iridium spark plugs??? fidgell Canada 4 03-01-2010 12:10 AM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 08:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
