A little teaser...
I've been without my Yaris for a few months now as it's been undergoing a heart transplant (drowned the engine going through a deep puddle while having a cold air feed tube from the fog light hole)... And today I got my first test drive of the slightly upgraded beast... There's still a lot to be done but wow, what fun, I understand what the boosted guys are talking about now :D
http://www.youtube.com/watch?v=sWzhuMHjBtc
![]() ![]() ![]() Drives: '10 Yaris LB Polar White Join Date: Oct 2010
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
Put all those gauges to use now
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
LOUD
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
やりすぎだ~
So many questions, so little time!!!
Just beautiful! How easy or difficult was the installation overall? What type of engine management are you using? What transmission and axles? Maybe from an AE92 or AE101 Corolla? Did you have to eliminate or reroute the A/C? I better stop here or the list of questions would go on and on. |
Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
no, no, no , no ,, no ,,, NO!!!!!!!!!
![]() Must get done w/ cosmetics modifcations quickly
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
eeek - going from a cross flow (front to back) to a cross flow (back to front)
what motor is that? more details please Will |
#8 | |||
Engine management is stock 4A-GZE's ECU + HKS V-con Vpro2 (the box of choice for local tuners) Transmission is actually the stock C50... the one that came with the 4A was simply too big to fit. They actually broke my original tranny (engine was tested at 300+hp then detuned to about 200 as it is now) and replaced it. Clutch also had to be replaced, now have a 6-puck copper based one. AC is still there, can't really survive without it when it's meltingly hot and humid outside :D Power steering had to be hacked a bit, though, they could not get the PS ECU to work properly, so it's not really speed-sensitive anymore... I think I can find a way to adjust the strength, though, it seems a little too light. Any other Questions? :D Quote:
![]() It's a late 90s 4A-GZE, with the supercharger removed (not enough space in the engine bay) and replaced by a turbo setup based around an IHI VF35 ball-bearing unit. (stock turbo from late-model Imprezas, quite responsive). It currently runs at the lowest boost possible, 0.7bar (around 10 psi), with an estimated power output of 200whp (still gotta dyno it, though). Boost comes on around 3000RPM and doesn't really let up til the 7500RPM redline ![]() But I had to let them take it back to the workshop, there is still some work to be done... The F-con is having some power supply problems and the car is very hard to get started. Also need to get some new gauges put in, like boost, wideband AF and a tach! As it turns out, they can't get the car's stock tach working... and since this engine redlines at 7,500 RPM, might as well get a new one...
| New Kit, New Wheels, New Tails (kinda teaser) | wildmongoose26 | Photo-Video-Media Gallery | 18 | 04-14-2011 12:56 AM |
| Upcoming Show Teaser | H3LlIoN | Mid-Atlantic | 22 | 06-29-2010 08:27 PM |
| a wee teaser | thebarber | General Yaris / Vitz Discussion | 1 | 05-05-2010 10:23 AM |
| Teaser shot!!!! | DuckinOut | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 11-25-2008 12:31 PM |
| Turbo Kit Teaser Pics | cdydjded | Performance Modifications | 27 | 01-31-2007 12:58 AM |
