#19 |
Corporate Slave
Drives: 2010 Yaris YX aka "Cutie" Join Date: Oct 2011
CAI not the lights, peru bumper mo baba.
K&N meron dito sa Riyadh or you could source it from the US pareho lang price
Si Vis Pacem Parabellum CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to. Keep your ride rockin and rollin |
#20 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
sidenote: pwede rin tanggalin ang driverside headlight for better access. |
#21 |
![]() Drives: Vios/Yaris Join Date: Apr 2012
Mas maganda ang CAI (Cold air Intake) setup mas malamig ang higop ng hangin kasi usally nasa likod/baba ng bumper ang cone nito malayo sa engine. As what syntax said long tube ang gagamitin. Advantage: Malakas ang hatak. Disadvantage: Prone sa alikabok, buhangin, tilamsik ng tubig. SRI naman usually common setup sa most cars.
#22 |
For me lang I prefer to use the K&N drop in filter. No modification/replacement sa tube ng intake. Para ka pa din naka stock iba lang ang gamit na filter iba na din ang higop ng hangin nya since you're using aftermarket filter. K&N the best. Check the web for reviews about this K&N drop in filter.
#23 | |
#24 |
Also note where the power/torque increase will be.
Stock intake box provides good torque in the low end of the rpm range SRI is more low to mid range pick up and won't make as much gains in the higher end CAI doesn't have much gains (might actually lose torque) in the lower end and is more useful in the mid to higher end of the rpm band So it all comes down to where in the rpm band you really drive in. |
#25 | |
#26 |
![]() ![]() ![]() Drives: Toyota Echo 2005 Join Date: May 2012
Pwede ba ito sa Toyota Echo 2005 1.3 engine...
#27 |
#28 |
ah ok... so pwede ko siguro tanggalin yung airfilter stock then palitan ko lang ng air filter na ksama ng Air Intake Kit para di na ko magpapacustomize ng Pipe since straight usually ang kasma ng mga ktis.... what you think kabayan Syntax
#29 | |
post ka naman ng picture ng engine bay mo para makita natin kung saan dadaan ang pipe at san ippwesto ang cone type na air filter, paki picture na rin ung sa may throttle body at maf location |
#30 |
Engine Bay pic
Kabayan syntax, eto yung engine bay pic ko
#31 |
check natin pre kung ano pwede, katulad din kasi ng layout nyan ang toyota Xa
#32 |
@ Syntax.... nakakita na ko ng Air Filter sa Olayan Car & Accessories.... yung K&N nasa 270SR.... yung SIMOTA 95SR lang... pwede na siguro un... Tanggalin ko na lang yung Air Box tapos gamit ako T-pipe para sa MAF sensor......
#33 | |
#34 |
plan ko is tanggalin ko lang yung Air box. yung hose from engine same pa rin. yung Air box papalitan ko lang ng air filter ng simota. problem ko ngayon is yung kakabitan ng MAF sensor since naka-built in sa air box yung lagayan ng MAF sensor.
#35 | |
wahhh
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter) |
#36 |
nope... bale ang mahihigop na hangin nun ay ung katabi ng engine which is hot air, not advisable pre' best option dyan ay ung nakakabit sa throttle body. mag fabricate ka ng tube para dun at ilalagay mo sa harap ng battery at likod ng headlights
| Cold air intake vs air intake | Liu997 | Performance Modifications | 15 | 11-05-2009 05:32 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
